Question about Initial Mobile DVD Player with 10.2" Widescreen Overhead Flip-Down LCD Monitor - IDM-FD10 Car Video Player
Initial IDMFD10 -How & where can I obtain the wireless headphones that work with this unit?
My sennhauser 110 only work on left speaker ,nothing ,no sound on right?????headphones
The first thing to do is to disconnect the Sennheiser wireless unit and try another headphone, preferably a cable type and see if both channels work. If the sound is OK on both channels, the fault is within the headphones. If you are lucky it will be the wireless unit plug or the cable and can easily be tested and repaired by somebody familiar with electronics. Otherwise you will probably need to have it repaired by a service shop or a technician. I hope the guarantee is stilll valid.
Sep 16, 2015 | Sennheiser RS-110 Wireless Headphones
Where can I get an instruction manual for Sylvania wireless headphones?
U.S. National Customer Service and Sales Center
(For products only)
General Lighting: 1.800.LIGHTBULB (1.800.544.4828)
Automotive Lighting: 1.800.347.3420
Consumer Products: 1.800.842.7010
Display/Optic: 1.888.677.2627
Electronic Control Systems (ECS): 1.800.654.0089
Industrial & Commercial: 1.800.255.5042
Special Lamps & Markets: 1.800.762.7191
Aug 13, 2014 | Sylvania SYL-WH930GB Wireless Headphones
BRAVIA 1080p  KDL40 V2500 & wireless headphone setup, WHERE DO I PLUG THEM IN.
Its a socket for the wireless unit? I would be interested in knowing the brand of the unit and if possible a better idea of what is broken--is it on the set or the wireless headphone unit?
I get a lot of people looking for a wireless unit they can use and I am willing to help you as much as possible.
There is on the page here a small "make a comment" button where you can reply to me--site will email me.
If you research me (SD TECH) YOU will see I am the top rated tech on this site.
This site is free (means a no pay site) so I do this for free to help as much as I can.
Regards, SD TECH
May 16, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The sound keeps breaking up the green light goes out and there is a terrible hissing sound
I know this is a bit late but i had the same issues with my unit. turns out if you listen with the source volume really low the headphones cant detect sound so they shut off. you fix this by simply adding more volume from the source and then just decrease volume on the actual headphones to obtain desired listening level and say goodbye to this issue.
Jan 17, 2011 | Sennheiser RS 110 Consumer Headphones
How do I install wireless headphones on a Panasonic Viera TV
Your wireless headphones work with input from the audio output to the device base. Connect this unit accordingly with the power for the unit. switch on the tv and set your headphones to the desired frequency to lock on. Hope you get this right. good day
Jul 02, 2010 | Panasonic RP-HVS20 Consumer Headphones
I have a Hohner amp that has sound coming from earphones when I plug them into the headphone jack, but there's no sound coming out of the speaker itself when the earphones are unplugged. How do I fix that?
the headphone socket acts as a switch for main audio and headphone line. either u have a defective socket or the power amp is defective. headphone line is driven by a preamp, which is working - if power amp is defective- headphone works but power amp fails. try changing the headphone socket first.
Apr 25, 2010 | Audio Players & Recorders
Wireless connection to laptop
Initially, pls verify that your laptop is set to "Obtain an IP address automatically". Additionally, pls post back the laptop brand/model, the WiFi card the laptop is using (add-on or built-in) and your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 27, 2008 | Linksys Wireless-G WRT54G Router
Cant get wireless to work
Since your ISP is new, you need to do a reset on the router. Reset involves pressing a small recessed button at the rear of the unit for about 10 seconds or more.
On the Vista PC, pls verify that it is set to Auto obtain IP add and to connect to your router/WiFi network even if the network is unsecured.
Thank you for using FixYa..
Apr 02, 2008 | Linksys Wireless-G WRT54G Router
Logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Car Audio & Video Logo
Top Initial Car Audio & Video Experts
xxxxxx xxx
Are you an Initial Car Audio and Video Expert? Answer questions, earn points and help others
