Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire fex 831 combo washer dryer... how do you get into it to replace any of the wheels I see mentioned in prior posts to stop the squeek of a dryer? I have removed a panel in the front to see the belt, but thats it. I also took a little door of in back that opened where the belt is but again not big enough and still can not see other wheels or even the "whole" drum.
SOURCE: Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Posted on Dec 26, 2007
ezed51
  • 7 Answers
SOURCE: Frigidaire Gallery Series Model # GLEH1642DS1 woint spin or agitate
CHECK LID SWITCH. DOES THE WATER DRAIN FROM UNIT
Posted on Jun 01, 2008
SOURCE: frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Posted on Nov 02, 2008
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
david04928
  • 102 Answers
SOURCE: How do I remove and replace the washer transmission
You can go here and get all the info you needhttp://www.appliancedesk.com/appliancedesk/service/Majestic/MJ9050V_service_manual.pdf
Posted on Mar 10, 2009
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Frigidaire model fex831cso serial xe34800123
Hello friend, we appreciate your post!
It appears you have a laundry center FEX831CS0 and that your dryer is not working. Can you provide me more specific details? Is your dryer not heating, not turning on, or not completing a cycle? For instance did you notice any strange functions or odd noises prior to this issue? With this information I can better address the issue at hand. Thank you - Matt
Jul 19, 2014 | Frigidaire FEX831CS Top Load Stacked...
My kenmore heavy duty extra large capacity 2 speed motor when drying my clothes squeeks when turning to dry clothes can I spray wd40 to make it stop squeeking and how or what do I oil?
Most likely a wheel bearing on the tub of a front loading washer, or the belt tensioner pulley on a top load washer. Either is not fixed by lubrication but replacement is called for. There are usually 3-4 wheels on front loaders that could be out. Replace all of them if you are going to replace one. The belt tensioner is a single assembly that can be ordered from any appliance parts warehouse or Sears.
Aug 01, 2012 | Kenmore Washing Machines
My dryer squeeks realy loud
If this is a Frigidaire dryer the rear drum support must be replaced.
If another brand please post the model number.
Sep 23, 2010 | Frigidaire FER311FS Electric Dryer
I cant find the heating element on a stackable fridgerdaire dryer
it is located in the cabinet of the dryer behind the drum the top needs to be removed and the front panel needs to be taken off then the drum removed
Sep 05, 2009 | Frigidaire Dryers
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
How do I remove and replace the washer transmission on fex model washer
Mar 10, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
44 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
