Removed memory from asr rock motherboard.I put the same memry stick back in and I am getting the dreadful 3 beeps not sure why,nothing else was changed
  • 85 Answers
You should try to reseat them again. Make sure the retaining clips are able to grab onto them and that they are inserted the correct way.
Posted on Mar 31, 2011
  • 61 Answers
Try putting the memory stick into a different bank and see if that does the trick....obivously you have put the stick in the right way....
If you still have a problem,the stick may be faulty due to the static in your fingers,what i tend to do,if i,m replacing anything onto a motherberboard i tend to hold on to the chasis of the tower or laptop to earth myself,or better still purchase a earthing wrist band.
it is rare but static from yourself can make some electrical components unuseable..
Hope this helps
  • DEKR
    DEKR Mar 31, 2011
    I used a wristband and i did try to seat it in a different bank
P4VM890 - 3 long beeps
1) Son follow Anti-Static Procedures?
Ram Memory could be cr@p now if not.
To include motherboard, processor, and graphics card; IF used.
2) All power cables attached to motherboard, AND tightly?
http://www.asrock.com/MB/overview.asp?Model=P4VM890
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
3) AMI BIOS 2.3.1
BIOS Beep Code - 3 Beeps
Indicates Ram Memory failure.
Cracked motherboard at ram memory slots, due to too much pressure being applied to motherboard, while in computer case?
Cracked motherboard at ram memory slots due to, user inadvertently had ram memory turned around backwards; and tried to install?
(Locating Notch was not lined up with Locating Lug, in ram memory slot)
4) We all get in a hurry sometimes, and make mistakes.
(Seen those commercials? Ha!)
Is there a 'stick' of ram memory in Slot 1? (DIMM 1)
That is the ram memory slot the Processor reads first.
5) I gotta' tell ya, Fred; I think we are dealing with a Static shock issue here, or cracked motherboard.
Was working, then ram memory removed/reinstalled; and now Not working.
For additional questions please post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Asrock P4VM890 Motherboard
Just built 2 computers all the same parts both beep 3 times at startup intel dg41wv motherboard
Three beeps usually indicates a memory failure on your board. Make sure that you have pushed your memory cards (ram) all the way into their slots until they click. If that does not solve your problem then your ram is incompatible with your motherboard and you will have to get new ram (or a new motherboard, but if you do that make sure the new motherboard still has the same socket size for your processor). Best of luck to you.
May 03, 2011 | Intel Computers & Internet
Five long beeps at a range of five seconds then, repeats
Five long beeps for a modern motherboards indicates a processor failure. If you wish to remove the processor and re-seat it (reconnect it to see if it begins to work again) make sure to get some thermal compound to put between the CPU chip and the heatsink. More info at: http://www.hardwaresecrets.com/article/How-To-Correctly-Apply-Thermal-Grease/274
POST AMI BIOS beep codes
  • 1 - Memory refresh timer error
  • 2 - Parity error in base memory (first 64 KiB block)
  • 3 - Base memory read/write test error
  • 4 - Mother board timer not operational (check all PSU to MB connectors seated)
  • 5 - Processor failure
  • 6 - 8042 Gate A20 test error (cannot switch to protected mode)
  • 7 - General exception error (processor exception interrupt error)
  • 8 - Display memory error (system video adapter)
  • 9 - AMI BIOS ROM checksum error
  • 10 - CMOS shutdown register read/write error
  • 11 - Cache memory test failed
  • 12 - Mother board does not detect a RAM module (continuous beeping)
Source: Wikipedia
Feb 28, 2011 | Computers & Internet
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Motherboard doesn't seem to want to access 3rd memry slot
Have you tried sticks in slots 1 and 3 with nothing in 2. If the third slot still doesn't work then its probably fried.
Sorry.
Jan 31, 2010 | QDI Group QDI SynactiX 5EP-A (SYNACTIZ...
Consecutive beeps last 10 seconds, silence for 5 seconds, the long beep for 10 seconds...pattern repeats. Nothing comes on screen. I removed single RAM card, tried other slot, same problem. I powered it on...
how many beeps any breaks between beeps and then how many like 3 beeps then stops for 1 sec then beep beep beep stop beep beep beep check to make sure that your installing your memory sticks right and they are seated all the way make sure all cards are seated right all wires are not shorting out and a worst case your cpu is good
Dec 25, 2009 | Biostar K8VGA-M Motherboard
3 short beeps.
This indicates a memory problem
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Sep 14, 2009 | EliteGroup K7VMM Motherboard
Turn on Pc and I get 3 beeps and it shuts off
make a clean the memory or replace the memory
May 23, 2009 | DFI AK74-SC Motherboard
3 beep sound
the 3 beeps means memory problem.
un-install the memories, take a look the stick and the slot. make sure they are in good condition.
reinsert the memory firmly, and make sure they are lock down.
if the still appear, you need to get new memories for the board.
Nov 12, 2008 | Intel D945GNT Motherboard
Computer turns on and beeps.
I suggest you check you memory sticks, and make sure they are seated properly. The long beep usually signifies a memory problem. If you have 2 memory sticks, I suggest removing 1 of them, then tuen on the PC, if it still beeps, powerdown by holding the power button in until it shuts down, then replace the removed one, and remove the other, if it boots, fine, then you will need to replace the memory that you have removed, but,,,,,if you only have 1 memory stick, I suggest you replace it, if the pc still beeps a long beep, then 1 of the memory sockets is bad, and a motherboard replacement is needed, either case, that long beep is a memory problem.
Jun 17, 2007 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
