Question about Garden
Wot type of oil do you use in wacker plate with honda engine
5 Suggested Answers
SOURCE: have a wacker plate with 4.5hp honda engine that
will it run with the fuel cap off if yes there is a vacuum in the fuel tank
caused by a blocked breather
if it will not run with fuel cap off the float valve could be blocked
Posted on Mar 07, 2010
SOURCE: what type of oil doesa honda gcv60 use?
GCV160 engines take 10W30 oil.
Posted on Jul 01, 2010
raygin
  • 322 Answers
SOURCE: i have a jaguar 3
The engine light shows a fault has occurred. The recorded fault will be visible if you have the codes read. One of the most common faults is the MAF (mass air flow sensor) this sometimes shows a wrong reading and logs as a fault, The light may go back out after the engine has completed another self check - if there is no ongoing fault. Get the codes read to be sure. .............. hope this helps
Posted on Feb 01, 2011
Testimonial: "great thanx problem solved air flow pipe split."
SOURCE: waker plate with honda g100 2.5hp engine leaking oil
  • i am after a manual for a honda G100 modle
Posted on Mar 02, 2011
Wot is the symbol 4 transmission oil
i guess you lost your glove box operators guide, already?
no !
RTM , read the manual,, see type ,grade, spec, and climate issues.
here it is (server can overload, so wait)
http://justgivemethedamnmanual.com/honda/honda-accord-owners-manuals/
Dec 30, 2013 | 2006 Honda Accord
How the emptying of the honda 1100 xx
wot you trying to empty on your bike ? engine oil ? Or the fuel tank ? ? more info please ! P....
Dec 03, 2013 | Honda CBR 1100 XX Super blackbird...
Why does my honda gx160 start and run for minute or two then cut off. Will restart
Hi, check the oil level. If low the oil guardian is cutting the spark. Regards Phil.
Aug 19, 2012 | 5.5 HP GX160 Engine
Wacker plate won't reverse
what is a wacker plate i wonder ,is this a point on the vehicle you hit with a big hammer if it doesnt start i wonder ?
Aug 18, 2012 | Cars & Trucks
Bike is bogging down under power, oil leaking from header pipe and tail pipe possibly from shot rings
wot make of 2 stroke oil you using ? wot fuel oil mix ratio ? per gal use 2.5 oz with quality race oil !
Apr 08, 2012 | 2003 Honda CR 125 R
Hi i have just bought a 140 pit bike and i am having clutch problem's it just doesn't seem to work at all i have tighten it up and still nothing and i have let it warm up for the oil but still...
clutch problems in bikes can be traced primarily to the incorrect oil used in the clutch plates
gear oil/ engine will cause slippage or stick pressure plates and any oil modifier is a no no
use only the recommended oil
Jul 06, 2017 | 2005 Honda FSC 600 S
Vt250 clutch slips blead system changed plates and oil worked fine for 10klms and now slips again
Make certain you use motorcycle four stroke engine oil, car oils will cause clutch problems and full synthetics can sometimes cause problems
Sep 29, 2011 | 1983 Honda VT 250 F
I have to put 1 quart of oil every other day. Why is my honda civic using so much oil?
cos its wot engines do when they need a rebuild or its leaking all over the highway,(if it is, you will be able to find your way home by following the slick !)
Jun 04, 2010 | 1994 Honda Civic
Have a wacker plate with 4.5hp honda engine that runs for 30secs. then cuts out. Starts up no prob but 30secs. later cuts out, also does not want to travel along with engine running, have to drag it, any...
Jan 10, 2010 | Hammering
Cbr 250 rr oil
any honda certified oil will do, but since its an older bike you gotta pay attention cause 2nd gears in older bikes tend to go out more often.
Dec 25, 2008 | 1996 Honda CBR 250 RR
Garden Logo
266 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
