Question about Dishwashers
My Zanussi ZSF 6128 dishwasher will not drain. The filter does not seem to be clogged and the pipe at the back is not kinked nor is it blocked as far as I can tell. What would be the next steps in troubleshooting this problem?
2 Suggested Answers
Trifect7
  • 57 Answers
SOURCE: dishwasher zanussi zsf 6128
Either it's not getting enough water to flip over to the next part of it's cycle (unlikely) or the water float gauge is not working properly.
When the dishwasher is cool, look for the float inside the dishwasher --usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring loaded). Lift out the float mechanism and clean around the float tube; many floats must be disconnected from below--to do this you'll have to remove the lower access panel. Rinse off the float, then replace it in the tube and be sure it moves up and down freely.
If you're experienced with minor repair work shut off the hot water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel, disassemble the valve to reveal the screen, clean debris from the screen, and reassemble. If the screen doesn't appear to be blocked, call a repairperson (they will probably need to replace the water intake valve).
If none of this helps, call a repair person. Any of several parts, including water inlet valve, pressure switch, and the timer or selector switch, may be faulty.
Posted on Mar 02, 2008
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
I have a Matsui MF2W dishwasher that will not drain. Theres always water in the bottom. The exit tube rises to the pipe at a height of 90cm which is < 100cm as ststed in the manual Could it be blocked?...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jul 21, 2011 | Dishwashers
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Water not draining from dishwasher modle number hotpoint DWF32P/29 how do i get to the hose to see if its blocked
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 08, 2011 | Dishwashers
My diswasher will not drain, it seems to have completed the cycle but the basin is full of water when it finishes.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Mar 25, 2011 | GE 24 in. GSD6200G Built-in Dishwasher
Dishwasher doesn't drain
Hi
Daniel
Nov 27, 2010 | Maytag Dishwasher
My dishwasher is not draining all the way where is the drain? Maybe it is plugged?
Hi
Oct 25, 2010 | GE Profile PDW8400J Built-in Dishwasher
My Zanussi Dishwasher ZDF231 is not draining properly and the display buttons keep flashing on and off and pausing the cycle.
Check the drain hose isn't kinked or blocked. Check the filter in the inside bottom of the isn't clogged.
Jul 06, 2009 | Electrolux Dishwashers
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Mar 22, 2008 | Dishwashers
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Dishwashers Logo
82 people viewed this question
Top Dishwashers Experts
