Question about Fellowes DM15C Shredder
PS026/B2 Won't turn on. - Fellowes DM15C Shredder
    Sergeant:
  • 192 Answers
It is designed not to turn on if the bag is full or if the door is ajar. If this is not the problem unplug it for 1 minute then plug it back in and it should work.
Let me know if this works and has helped and if I can assist you with anything else.
Thanks
Posted on Mar 31, 2011
Can i connect 8 b2 and 4 l1 model 2 and play at the same time as dj
For each Model II Power Stand you can connect one B2, then run the bass line out to a PackLite Power Amp to power a second B2. To do what you want, you will need 4 PackLite Amps.
Bose PackLite power amplifier Model A1 Accessories L1 reg portable...
Mar 19, 2014 | Bose Dual L1 Model II w/ 2 x B2 Sub & T1...
What do b2 mean for a 2009 mercedes c 300
The B2 means the car needs the B2 maintenance service, call the MB dealer for details.
Feb 16, 2012 | 2009 Mercedes-Benz C-Class
The vacuum was on when my son tripped the cord and one prong broke off in the outlet. We patched on another cord. It won't turn on tried other outlets. Can't find reset switch, is there one or did we...
Maybe you got the wires crossed between the two cords. Vacuums have polarized plugs and if wired imcorrectly can definitely cause the vacuum to not work. Try switching over.
In other words, consider current wires as A1/A2 and B1/B2. Disconnect, then connect A1 to B2 and A2 to B1.
vacuum===============A1 A2=======Plug
===============B1 B2=======Plug
Switch to
vacuum===============A1 B2=======Plug
===============B1 A2=======Plug
Try this and see what happens.
Jan 03, 2011 | Dyson DC14 All floors Bagless Upright...
In 3 buckets, two Buckets filled with 20 litres of water, first- 19 litres capacity(max) second- 13 litres capacity(max)-Filled third- 7 litres capacity(max) -Filled i need to fill 2 buckets with 10...
Assume the following:
B1 = 19 litres capacity
B2 = 13 litres capacity
B3 = 7 litres capacity
B2 and B3 are full. The answer is:
1. Pour 2 litres from B3 to B1
2. Pour 8 litres from B2 to B1
3. Pour the remaining 5 litres in B3 to B2
Another answer:
1. Pour 10 litres from B2 to B1
2. Pour 7 litres from B3 to B2
In both answers you will get 10 litres in two buckets.
Rate if this answer was helpful.
Thanks
Oct 22, 2010 | Computers & Internet
I need to purchase the waste basket for the PS026/B2. The tab that fits into the shredder has broken.or is there A method to repair mine?
Hello. If you still have the tab you can use a one minute epoxy adhesive to refasten it. If not, you can go to the store that carries your brand and have them order you a new basket. J.
Jun 09, 2010 | Office Equipment & Supplies
I am in British Columbia, Canada. I am trying to move a ceiling light back to its original box. I can connect the wires so that the light goes on, but I cannot control it using a light switch. The box has...
I had a difficult time following your explanation of which wires worked. Therefore I would approach the problem in the following manner. First make sure your electricity is off. Get a voltmeter and determine which pair of wires (one white, one black) go to your ceiling light. You can check continuity from the light socket to the wires in the box on the wall. This will be one side of your circuit on the switch. Then turn the electricity on and determine which pair of wires have electricity flowing to them. Be careful here as you are working with live wires. The remaining pair may run to another outlet and should not have any juice going to them. You may want to check and see if all of your nearby outlets function. If an outlet does not function, you will have to tie these wires together with the ones providing the electricity. Be safe and good luck!
Mar 09, 2010 | Hammering
Broken....
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 11, 2009 | Fellowes DM15C Shredder
Formula for Calculating the turn around time in excel
dpprash,
I guess you mean the number of weekdays (or working days) excluding Saturdays and Sundays. So start a spreadshhet and put the start date (01/01/2009) in A2 and the end date (31/12/2009?) in B2.
Then paste the formula below into C2:
=B2-A2-2*INT((B2-A2+WEEKDAY(A2,3))/7)-MAX(0,WEEKDAY(B2,3)-4
better-swiss
Dec 18, 2008 | Microsoft Excel for PC
I need codes for telewest 5a 01,27 th nov 10:30 am
e8/25/93/b2/6a/90/0e/a2
16/cf/0c/a7/a7/14/d2/22
27/11/08/t/w/v/m/s/v
Nov 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
May 17, 2007 | Miele H348 B2 Electric Double Oven
Fellowes DM15C Shredder Logo
56 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
