Question about Refrigerators
I don't see leveling legs, only the rollers - Refrigerators
    Sergeant:
    Champion:
  • 202 Answers
Some only have rollers not legs
Posted on Mar 31, 2011
We have a Whirlpool refrigerator model EB9SHKXVQ02 that is not level. The front of the unit is at least a half inch higher than the back and we see four wheels but only one leveler on the hing. How do...
Place a cedar shake on the low side of the floor align with the rear roller, slide the unit into position and adjust the front leveling legs.
Oct 30, 2013 | Refrigerators
Leveling kenmore elite front loader
  • Place the level on the top of the washing machineicon1.png to see if it is level. Make sure you test it side to side and front to back.
    Pull the washing machine away from any walls if you have to make an adjustment to the legs.
  • Lift the washericon1.png and place the wood block underneath the washer. Place the block near the leg that needs to be adjusted, but don't let it obstruct the leg.
  • Loosen the nut that secures the legicon1.png with the wrench.
  • Raise the height of the leg by twisting it to the left, or lower the height by twisting it to the right.
  • Remove the block of wood from under the washer and recheck the machine with the level.
  • Raise or lower the leg if additional adjustments are needed.
  • Tighten the nut on the leg with the wrench when the machine is level.
  • Repeat the process for each leg that needs to be adjusted.
  • Move the washer back into position and check with the level again to make sure the washer remains stable to finish leveling the machine.
    Regards,
    Richard Roth
    http://appliancecafe.com
  • Nov 13, 2012 | Kenmore Elite 45986 Front Load Washer
    How to level a Whirlpool Conquest refrigerator 2009 after moving it from a different house? The left front now wobbles.
    To level your refrigerator:
    Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
    Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
    Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
    We just purchashed a Frgidaire Freezer model #LFFH21F7HWG. Does it have leveling legs on the back as well as the front? Are we missing 2 leveling legs?
    usually the back wheels are rollers that allow you to pull the fridge straight out from the wall, so NO, not leveling in the back, but you don't need it anyway, just use the front adjustments
    Mar 17, 2011 | Frigidaire 20.6 cu. ft. / 583 liter...
    Need to get refrigerator levelled. How do I do it
    Jan 16, 2011 | Refrigerators
    Open door and whole unit moves, it dosen't come with back legs, or does it??
    No most don't have rear legs. However, they usually will have front legs that screw down past the wheels/rollers to prevent it from sliding around under normal conditions.
    You may have to remove the grill in the front (if present on your model) to adjust the wheels/rollers "up" out of the way while lowering the legs to level it, and they should also act as "brakes" to a degree if the floor/surface is relatively level.
    Hope that helps,
    Good Luck
    Oct 31, 2009 | Kenmore 60721 Refrigerator
    How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
    Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
    May 02, 2009 | Amana ATB2132ARQ 33" Top Freezer...
    Re: Removing the upper fuser roller assemble.
    I am not sure what the black legs do but they problably support the heater lamps....if there is a wire going to the legs then the black legs need to be removed. the key is to d isassemble any drive chains, brackets etc that support the fuser rollers the black legs could also be support for stripper fingers
    just dissasemble all components holdng the fuser roller from both sides
    best of luck
    Jan 17, 2009 | Office Equipment & Supplies
    How to level the front wheels
    MOST ALL MANUALS GIVE DIRECTIONS FOR MORE THAN ONE MODEL INCLUDING FEATURES THAT MAY NOT BE ON YOUR MODEL. SOME DO NOT HAVE ADJUSTABLE ROLLERS BUT INSTEAD HAVE A FIXED ROLLER AND A SET OF LEGS TO BE SCREWED INTO THE SOCKET AT THE FRONT CORNERS AND ADJUSTMENTS MADE WITH THE LEGS.
    Feb 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
