Question about Samsung WF337AA Front Load Washer
Door will not open turn off power retried - Samsung WF337AA Front Load Washer
    Sergeant:
    Champion:
  • 202 Answers
Hi... clean out your drain pump and I bet your door will open when you power it back up and start a load then hit cancel
Posted on Mar 31, 2011
Replaced sprocket,now unit moves 2" forward then reverses and stops.
Look at the back of the door opener; you can see slot switches to limit up and down movement, give it a try to turn them back and retry, making the adjustments as you go along.
Jul 08, 2015 | Building Materials
How to sole Canon IR 1600 check printer cover error
(1)
If one of the doors on the Cassette Pedestal is open, then the main unit will display the 'check printer cover' message. Check to make certain all of the doors on the Cassette Pedestal are completely closed.
Note: These doors are located on the lower left side.
(2)
In service mode: (DORSW1/DORSW2) tested good.
Solution :
It may be necessary to refit the vertical path guide for cassette if it was not hitting the retry sensor, PS152, in the cassette unit.
Note that every cassette has a retry sensor (PS152).
(3)
Paper is "crunched" into the Retry sensor.
May 15, 2014 | Canon Office Equipment & Supplies
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
Sliding door
It may have a switch which engages when the door is fully open, if the switch is bad then the door would continue to try to open (too far)
Nov 01, 2013 | 2007 Honda Odyssey
The door is locked on the range and can't open
Try to turn the circuit breaker off to the home for about 10-15 minutes, then retry the unit. If the door does not unlatch then either the door latch assembly or main control board need to be replaced, since they are not communicating correctly. Consult a professional at that point to be safe.
Feb 13, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Fridgidaire fafs4272lwo door open error
Make sure the latch is not broken on the door. Retry. If this continues contact a professional so the latch and door assembly can be diagnosed. Also check to see if the door is sagging down at all.
Aug 02, 2012 | Frigidaire FAFS4272LW Washer
Clock works, locked door appears and door is locked, burners do not work
locked door appears In the clock display?? this is the eoc telling us that there is a problem with the door interlock or it's system . however this has nothing to do with the top burners/ there independent of the oven system . now when there is a code in the display. the oven will not heat and you may not be able to dor open . this is a job for service tec . turn off power for 15 min. and retry .mm
Nov 22, 2009 | Frigidaire PLEF398AC Electric Kitchen...
My LG WD-8074FHB door will not open
Door assembly needs replacing, can open door using old credit card/drivers licence, sliding between cabinet and door(toward centre area of handle-behind it), pushing the door lock in left hand direction, you can remove the items from machine.
Sep 19, 2009 | Washing Machines
Door will not close. led blinking 5 times
Is your door open or closed? If you release the door is it easy to open and close manually? Does the opener run with the door released?
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
We accidently left the freezer door open during the entire night and now icemaker doesn't dispense on monogram refrigerator, even though ice maker makes ice.
you might want to turn the whole fridge off (remove the food to a safe place) and let the fridge defrost, wipe any water up and retry. If it is under warranty, call GE
Nov 26, 2008 | GE Monogram ZDI15C Automatic Icemaker
Samsung WF337AA Front Load Washer Logo
61 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
