Question about Car Audio & Video
Help me hook up a sparkomatic sr430 cassette in a 1991 plymoth sundance
2 Suggested Answers
jturcotte
  • 8836 Answers
SOURCE: i need to know the
Hi, below are the colors of the wires in your car. Is this what you needed?
1991 Plymouth Sundance Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Red/White
Car Radio Ground Wire: Back Strap
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: Orange/White
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Green/Yellow
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Purple/Yellow
Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Shelves
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Brown/Yellow
Right Rear Speaker Wire (+): Blue/Red
Right Rear Speaker Wire (-): Blue/White
Posted on Mar 31, 2011
What code 44 on a plymouth sundance 1991
Generally speaking, code 12 means the battery has been disconnected at some point in time.
Code 44 means the battery temp sensor circuit is out of normal range, too high or too low.
Oct 03, 2012 | 1988 Plymouth Sundance
My 91 sundance doesnt want to shift over to the third gear.There is trasmission fluid .dont know if this is somthing serious.it has a automatic trans. with a 2.2. liter engine
Seen this twice. Chrysler has a fail safe to lock the transmission in 2nd gear when a problem is detected. Could be a bad filter or a solenoid. Unless you know much about transmissions it is easier to go to a shop and have them do a computer hook-up to isolate the problem.
Aug 26, 2011 | 1991 Plymouth Sundance
I have a 1991 plymoth sundance and the turn signal blinkers dont work but the wipers do I have checked the fuse what else could it be
Hi, there is a flasher relay behind the glove box. Find this, pull it straight out of the socket and replace it. You can get one at any auto parts store.
Mar 31, 2011 | 1991 Plymouth Sundance
I need to know the wiring diagarm so i can wire it to my 1991 plymoth sundance can you help
Mar 31, 2011 | Car Audio & Video
I have a 1991 plymoth sundance putting a after market radio in it i put the speakers in hook them up turn the volume all the way up and the music sounds real low what is the problem please
Sounds to me like the speaker wires may be reversed but then again I'm not perfect, just don't tell my wife that. Anyhow here is the wiring info for your vehicle just to double check. I hope this helps you and good luck.
1987-93 Plymouth Sundance Stereo Wiring Constant 12V+ Pink Switched 12V+ Red/White Ground Ground/Back Strap Illumination n/a Dimmer Orange/White Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 5" x 7" Side Shelves Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
Mar 28, 2011 | 1991 Plymouth Sundance
Hello can you tell me how long and how hard it is to enstall a brake booster in a plymoth sundance 1994
If there is proper add on kit available , it becomes easy to fix it provided that it matches with the existing unit.
It can be done in a day, to add on the fittings , giving the vacuum feed and bleeding off.
But all the wheel cylinders must be checked when the efficiency is improved.
Sep 27, 2010 | 1991 Plymouth Sundance
Need diagram for sparkomatic equalizer for car stereo
Not sure if they kept the old Sparkomatic diagrams or not but, the company Altec Lansing Technologies is/was the former Sparkomatic company. http://iratec.50megs.com/index.html is worth a shot if you have not yet solved your issue. They repair a lot of the old Altec equipment
Sep 09, 2010 | Car Audio & Video
Where is te starter on a 1991 plymouth sundance what is it hooked
The starter is located on the bottom of the engine, where the engine and transmission meet. It is on the side of the engine closest to the front of the car. The easiest way to find it is to follow the positive battery cable, as it goes directly from the battery to the starter solenoid.
Jan 22, 2010 | 1991 Plymouth Sundance
Digram on replacing heater core
i have a manual with step by step instructions,no diagram but helpful.
if you still need it i can scan it and email it to you
Oct 16, 2008 | 1992 Plymouth Sundance
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
