Question about Samsung 225BW Monitor
Monitor dosent work but has flashing blue power light
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 01, 2011
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
Power blue light flashing when i turn the computer on
It depends on where the blue light is. Is the blue light on the monitor or on the computer tower? If it is on the monitor the monitor is having problems and needs to be serviced. If it is on the tower it could be an issue with the power supply.
Jan 17, 2013 | Gateway DX4720-03 PC Desktop
What are bad caps
you will noticed if the capacitors at the power supply board is bad if has bulged to its casing or blown up. but sometimes even with out sign of bulged but its leak, you can determined this by using a capacitance meter.
Oct 27, 2012 | Acer 17" AL1706B LCD Monitor
Blue light flickers, but no picture
I have a gatway fpd2185w the blue light blinks and then dims and the power button dosent work.
Jun 28, 2009 | Gateway FPD2185W 21 in. LCD Television
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Power light Flashes on and off stays blue
Hi...there,
It's seems you got a busted AD Board... your LCD bios had been damaged or erased.
Dec 01, 2008 | Computers & Internet
LG Monitor L194WT - Indicator Lights Flashing
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it ! warranty or new monitor
Jun 19, 2008 | Computers & Internet
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Samsung 225BW Monitor Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
