Question about PfaFF Sewing Machines
The foot control just stopped on my Pfaff 7560 (1998 model). The machine was still on, I was just sewing along doing a plain old zigzag stitch and all of a sudden no power from the foot control. Would this be an internal problem with the machine or computer, or actually the foot control. Is there a fuse that involves the foot control?
  • 456 Answers
Hi.
if there is power to the machine itself then it is probably not the fuse. if the entire machine is off then you need to change the main fuse in the plug (the one you plug into the wall socket).
first, unplug the pedal from the machine and plug it back in securely again. it may have just worked loose.
if the machine itself still has power,it may be an internal fault in the pedal, but it is quite likely that there is a broken wire in the foot pedal.
this is a fairly common problem with sewing machines as the foot pedal gets moved about and has the cord wrapped up when the machine is put away. eventually this can break one of the wires in the same way that bending a paperclip repeatedly will snap it.
if this is the case then the break will almost certainly be within 1" of the pedal.
it can be repaired quite easily by cutting out the break and reconnecting the wire inside the pedal but i would not recommend trying this yourself unless you are quite confident with electrical wiring.
an electrician would also be able to test that the footpedal itself is working properly and rule out any faults with the pedal itself.
please feel free to ask for more details if you have a 240v electrical test meter and would like detailed testing instructions.
Posted on Mar 31, 2011
Pfaff 6230 Foot Control quit working. Light behind Stitch panel, speed, needle down, & 1 stitch at a time doesn't light up. Are these 2 problems? What do I need besides replacing Foot Control?
Um, it could be no power to your machine, I would suspect it is the power cord, plug or possibly an internal electrical issue. If the foot control failed, the machine's light should still work.
Nov 12, 2016 | PfaFF Sewing Machines
I have a pfaff 261 when the knee pressor is engaged the motor runs but the needle doesn't engage. If i turn the wheel by hand the needle will engage.
First, stop running the motor if the machine is not operating. Most likely the old oil has stuck things together. Continued operation of the motor in such condition could burn up the motor or break a gear.
Pfaff 130 wheel sticks
Will not zigzag or decorative stitches New to these newer plastic style...
Nov 10, 2016 | PfaFF Sewing Machines
Pfaff Passport 2 How do I get zigzag stitch to work?
The manual instruction begins on page 21. Have you looked there how to select a stitch and how to adjust the width?
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/passport-line/passport2_0/Manual/passport_2_0-manual-EN.pdf
Aug 26, 2014 | Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Someone gave me a Life style Pfaff sewing machine and I don't have the manual. I would like to know how to use the rolled hem foot and need to purchase a pipping foot. A foot to make pipping, 1/4 -...
I would suggest you contact Pfaff firstly to see if you can obtain a manual, its always worth having the one for your machine. I presume you are in the USA? if yes, go to www.pfaffusa.com or ring toll free 1-800-446-2333 Monday-Friday 8:00a - 4:00p CST or email info@pfaff.com
or go to www.pfaff.com then choose your own country then go to "contact us". and find the details.
Using a rolled hem foot is the same on all sewing machines, you are introducing the cut edge of the fabric into the front of the foot and it rolls the cut edge twice, as you seam over it. Its fiddly, you need a straight trimmed edge, and you have to keep the same amount going into the foot for it to work. You can either straight stitch or do a small zigzag over the fabric. Getting it started is the hardest bit because you need something through the foot to stitch on so it doesn't just get pulled into the hole on the needle plate.
try this link http://sewing.about.com/library/sewnews/library/aatech0803.htm for a bit more info on this, some machine makes sell a 2mm, 4mm or 6mm foot for different weights of fabric and finishes. You can buy accessories for your pfaff from www.sewingpartsonline.com or from Pfaff. Pfaff website even has free projects and a newsletter for customers.
Just put the foot on, lower the pressure foot onto the edge of the fabric, do a couple of straight stitches, then raise the pressure foot and pull the fabric back an inch, so you have something to hang onto at the back, then put 1/4 of fabric into the open part of the foot, hold it there, lower the pressure foot and start stitching, keep a bit of fabric turned in in front of the foot so you help it go into the foot and try to keep it a constant width, trial and error, you'll soon get the hang of it.
Piping can often be done with your zipper foot, you just want to encase the piping cord with a bias cut fabric strip and stitch as close to the edge of the cord as you can to hold it nice and tight. Then put the piping strip between two pieces of fabric and again stitch close to the cord so the first line of stitching doesn't show. Some machines, the zipper foot will have a guide so you can squeeze the cord up against the foot. Here is a link for piping techniques http://sewing.about.com/od/techniques/a/covercording.htm and covering cord http://sewing.about.com/od/techniques/ss/cordingpiping.htm
Just cut the bias strip width to suit your cord width, join the bias strips together if you want lots of length, then wrap fabric around the cord, right side out, put it under the zipper foot and stitch through the fabric as close to the cord as you can, on some machines you can adjust the needle position to get close but check your manual for help on this, you don't want to strike the foot, just sew up close to it.
I haven't done double piping, but I presume you would sew two layers of piping on top of each other?
I've got a old "Sewing Soft Furnishings" text book that I found at the op shop for $2, the images are daggy but the techniques don't change, most furnishing stuff is just taking measurements, adding seam allowances, and sewing straight seams, so the machine doesn't have to be fancy, or need lots of accessories, just know-how. What you do need is a strong machine to sew upholstery fabric, many domestic machines just won't handle heavy weight fabrics too well. Large sized needles 110 size will be important too.
I'd suggest you try one of Debbie's free pillow guides as a start http://sewing.about.com/lr/free_pillow_projects/271734/4/ , go for something without a zipper at first, and once you've made a couple of easy pillows, your confidence will grow.
Good luck with your Pfaff and enjoy your sewing.
May 20, 2011 | Sewing Machines
When buying a sewing machine that has blind hemming feature .what does this mean./
it means there is a foot included that will straight-stitch a certain number of stitches then do a zigzag stitch to the left that will catch the fold of the fabric at intervals. The fold is made at the width of the hem you want. When you finish and straighten the hem out, the hem stitches will barely be visible on the top side unlike straight-stitching across the top of the fabric. There will be a "hem stitch" option on the machine and the foot will possibly have a movable guide that runs along the fold of the fabric to where your zigzag "catching the folded fabric" stitch is consistent.
Mar 21, 2011 | Sewing Machines
I can't get my Pfaff 230a to straight stitch!
The stitch selector switch is most likely the culprit. Have you tried operating the machine upside down?
Jan 17, 2010 | PfaFF Sewing Machines
Zigzag not working
Download the users manual here if you don't have one. PFAFF users manual.
Nov 17, 2009 | PfaFF Hobby 4260
Pfaff triptronic 2040 sewing machine
Could be a couple of things:
  1. Foot control is bad - take foot control to your local Pfaff dealer to try on one of their machines. If their machine won't run either, it's the foot control and you can look into repair/replacement.
  2. Machine has a short or some type or computer board problem - take machine to local Pfaff dealer and try with one of their known working foot controls. If the machine still doesn't work, your dealer will need to diagnose what is wrong.
Hope this helps.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Oct 01, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
75 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
