I have an Armstrong Air gas furnace Model # G1D91BU075D16C-1A that I have a code 7 on and I can not find the codes anywhere. Could someone please help me out. Thanks.
4 Suggested Answers
  • 85 Answers
SOURCE: I have a problem with
Buy a new ignitor either from the ignitor store online, or your local distributer, Contracter, dealer.. they usually run from 15 dollars to 35. Their simple to change out and deffinite do it yourselfer... Oh and turn off power at breaker panel, you don't need any unexpected surprises!!
Posted on Dec 02, 2008
  • 5 Answers
SOURCE: High limit switch open on armstrong furnace
If you know where the high limit switch is you can always cut the two wires and wire them together causing the limit to close. But what you have to watch out for is why the high limit is not closing. That means in your return air either you have a dirty return air duct, dirty filter, or you don't have all your registors open to allow the heat to escape the heat exchanger. Just watch over riding the system. The high limit switch should either be on or behind the blower, in the middle of the system right under the heat exchanger. any other questions about hvac just ask.
David
Posted on Jan 17, 2009
shastalaker7
  • 1515 Answers
SOURCE: Armstrong Heat pump Package Unit, Model#1B36DA-9B,
Hi, the outdoor unit will start to freeze when it is cold outside, but also it should go into a defrost mode to melt this ice either by the defrost board or defrost thermostat. You will know as steam will rise like smoke and some folks think it is on fire. If it never goes into defrost, get back to us and we can go through some things to check. Merry Christmas,
Shastalaker7
Posted on Dec 24, 2009
I have a Armstrong SX80 gas furnace, T-stat calls for heat, combustion fan starts, in 1 1/2 min burner lights,this month t-stat calls for heat, combustion fan starts no burner ignition,
Check pressure switch and hoses to it . check air filter is clean . check you have gas in the line . check connections on gas valve check flame sensor
Dec 05, 2017 | Heating & Cooling
PGB036100-1A Goodman furnace... I have no heat, the circuit board is blinks red twice? I need help cause i can not afford to have someone to come fix it? Please help me!!!!
The error codes, blinking red twice, should be described on the electrical diagram which is probably on the back of the panel you had to remove to see the circuit board. If not there, check the manual, which you can probably download.
Nov 12, 2013 | Heating & Cooling
Armstrong eg6g75dc104
it should be on the inside of the door look for flash codes there is no code book you just have to know post code and what it says on the door and I can help
I have a gas furnace model # 2sg13b36090p-1a green light flashing 2 times slow
Hello, Maybe this will help you some.
http://home.howstuffworks.com/how-to-repair-gas-furnaces.htm
I hope it does, Mike
Oct 26, 2011 | Coleman Propane Forced Air Heater...
I have 1990 Armstrong gas furnace Ultra III 80, Model EG6G75dc8-4 .\r\nWhen I turn thermostat up , furnace comes on, burners come on, motor that I believe turns blower turns on but i AM NOT GETTING AIR...
have you checked your filter yet? the other thing to check is open the fan door and jumper the door switch,if there is one, and turn the furnace on. is the fan blowing air now?
Mar 22, 2011 | Heating & Cooling
I have a armstrong gas furnace and I would like a wiring diagram for it it is a model mg73140
http://www.armstrongair.com/armstrong-links/
from here select the particular furnace that you have this is the only resource the is avail. due to the furnace being a Lennox made furnace
Mar 07, 2011 | Heating & Cooling
Can anybody identify this airhandler/furnace? MOD# GNJ075M12A1. SER# NTN5075BFA1. THERE IS ALSO AN A-COIL IN A CABINET BUT I DONT THINK IT GOES WITH THIS UNIT. MOD#C2E30B-1A SER# 6002B0483. IT ALSO HAS AN...
Your Gas Furnace is a Comfortmaker.
The Evaporator Coil is an Armstrong.
Hope you find this to be very helpful.
Please leave a rating for me. :-)
May 14, 2010 | Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
