Question about Car Audio & Video
Still doesnt work
My system doesnt work i have tried a couple of things and have blown 5-6 fuses.....ii still need help on the problem......
  • wilson756168 Aug 05, 2008
    the make of the battery is a nautilus xhd-m-24
    the make of the deck is a panasonic cq-c8303u
    i currently have 2 speakers hooked up the other 2 are just bare wires
    the speakers are new
    yes the sub is bridged
    as far as i can see there is no shorted wires
    and no i dont have a continuity tester at this time i do have a greenlee gt-11 voltage detector if that helps
    Brigadier General:
  • 6,966 Answers
If you may pls:
  • post back make and model;
  • detail circumstances prior to the fuse blowing;
  • how many speakers are connected;
  • have you checked the speakers themselves;
  • is it a sub in bridge mode;
  • have you checked the polarity, possible wire short or grounded
  • do you have access to and familiar with a continuity tester (DVM)?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 05, 2008
OBD II system not communicating with state inspection machine or scan tool! 2002 kia Sedona
Turn you ignition switch to the on position ,does the CK ENG Lite appear, if yes this is a good indication. Your DLC (diagnostic link connector) should have battery voltage at pin 16 and ground at 4 and 5,If you can verify that your vehicle has this working order then its there problem and not yours
Mar 03, 2012 | 2002 Kia Sedona
I have a 06 equinox i was told to replace map sensor to make heater work i did it, doesnt heat blower works what maybe the problem?
It could be a couple of things. It could be your heating element. It may also be a loose wire or a blown fuse.
Feb 03, 2011 | 2005 Chevrolet Equinox
Blown fuse, power adapters and radio not working
check the fuses under the hood, thats where the power outlet fuse is located, but also check under the dash box if radio still doesnt work after replacing fuse under the hood.
Dec 21, 2009 | 2005 Dodge Caravan
Insinkerator badger 5 doesnt turn on
Make sure that the fuse/breaker is not blown/tripped You could take a voltmeter and check for voltage at the unit. Hope this helps
Sep 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Spilt water on my djm 500 and now it is not working at all. Is it repairable? I've checked the fuse in side and that is ok, has it fried the circuit boards?
I can guarantee that you have fried the circuits, ive done the same thing a couple of times.
electronics and beverages doesnt like each other.
Please rate my solution:)
Feb 10, 2009 | Pioneer DJm500 Professional DJ Mixer...
Engine analyzer broken
U need to find out why the system won't self test with the scanner, u have been to a dealer or just some outside shop? Also check the cigar lighter/power point fuse, if it is blown out the system will not self test, the fuse is in the inside fuse box behind the panel to the left of the steering wheel.
FUSE #3 20A (YELLOW FUSE) Cigar Lighter, OBD-II Scan Tool Connector (12 VOLT POWER SOURCE)
Jan 22, 2009 | 1999 Ford Expedition
My 2006 Kia Spectra's windshield washer isn't working. When I pull the lever to start the washing I hear a couple of knocks to the passenger side dash area, but the washer doesnt work. I haven't seen any...
you know..i have a 2002 kia spectra and for the longest time i didn't have a washer cap on my windshield washer tube..i finaly found one in a junk yard and popped it on so i could have a windshield washer that actually works..and it still doesnt.
Sep 27, 2008 | 2003 Kia Spectra
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
