Question about Samsung CLP 300 Laser Printer
Printer not working
The printer is connected as when I look at printers it is listed, however it won't print and it is not even listing my print request. It is blinking the red light.
Janice K
    Genius:
  • 2,785 Answers
Dear janice
plz try by reinstalling the printer driver, if the problem is not solved then check the ink status and try by another usb cable
Posted on Aug 05, 2008
My printer suddenly will not take the print command from my computer. What do I do to fix this?
Redo the software drivers for the printer. Go to their web page and download the new driver set.
Feb 02, 2015 | Office Equipment & Supplies
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
Aug 07, 2011 | HP Deskjet 6980 InkJet Photo Printer
I can not get anything to print on my Epson NX420 using my IMAC. It says the printer is offline and I can't even print a test page. Can you help?
I'm assuming the printer worked previously from the iMac and now it does not. If you never had it connected, please add a comment to this effect, and include your OS version.
First, Open the Print Center (Printer Utility) and check the status of the printer. It may be listed as stopped. If so, delete any extra print jobs (additional attempts to print the page), then click the Start Jobs icon.
You can verify printer connectivity by clicking Add in the Printer List (if that is not visible, select Show Printer List from the View menu). Be sure to select either the USB or wireless network protocol connection. If the NX420 shows up, you have a good connection. In that case, click cancel and skip the next paragraph.
If you are printing via USB, check the cable (I sometimes forget to plug in my printer cable after downloading from my camera). If you are printing via your wireless network, check the status of the wireless connection from the printer.
Also, in the printer utility window, click the Supply Levels icon to verify that all of the ink cartridge levels are high enough to permit printing.
Are there any error messages on the printer display? A fault detection will take the printer offline.
Jun 22, 2011 | Epson Printer
When I try to print from my PC the printer doesn't respond at all even though the cable is connected on both ends and the printer is turned on. Worked fine the day before.
I assume you are using a PC- All printers have a list of pending jobs refered to as the print "queue"- it should open if you double click on the default ptinter icon in the printer list- it sounds to me like your print Queue has been paused somehow and all the print jobs are being "held" until you tell the queue to restart printing
Jun 01, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is http://192.168.1.5/lp1. Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
Not Printing. Reinstalled the software, reset printer to factory
If you are running Leopard, reset the printing system by control-clicking in the list of printers in the Print & Fax preference window. Then reinstall the drivers.
Apple Menu > System Preferences > Print & Fax. Control Click in the left area which shows the list of printers, and choose "reset the printing system"
macs2u
Apr 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printing error
From your start menu, go to printers and faxes area. When this opens do you see your printer listed? Is it greyed out at all or maybe listed as offline? How are you connected tot he computer? Network, USB, or parallel port connection? If you see your printer listed and it has no other duplicate listings, right click the printer and go to properties, then choose the Ports tab. Verify here that the port selected witha check mark corresponds with your connection method. Example: If you are connected through USB, your selected port should say USB. Sometimes DOT4 ports will work for USB connections too. If you see this option, you can select it and hit apply to try it out. Try to print a test page after each applied change. Also, make sure that print jobs haven't built up in your queue by double-clicking your printer icon. If there is a queue of failed print jobs, select them and cancel. This might take a moment to complete. If your printer icon is greyed out, right-click it and un-choose the work-offline option and try it.
Mar 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Not Showing In Printer List
that printer works well with direct printer to computer usb connection.
remove the printer from the printer list then connect the printer directly to the computer and add it again.
Sep 06, 2008 | Epson Stylus Photo R200 InkJet Printer
My printer
If you're using a MAC System
> Delete the printer in the printer list ( make sure that there's no printer left in the printer list for the CX 8400 )
> Click on the plus sign to add the printer again in the printer list
in the Printer Brouser window you should see the printer listed there via USB connection., Click on it and check under
"Print Using" if the CX8400 driver is listed ( not a guten print driver )
> If CX8400 driver is listed under Print Using., click on add and try to print.
> If "guten print driver" or no driver selected you may need to uninstall the printer driver and download a driver from the epson website.
Steps to uninstall the printer driver:
1.) Make sure that the printer is deleted from the printer list
2.) Click and open MAC or Apple HD / Library / Printer., and look for the Epson folder (drag the whole Epson Folder to your trash bin)
3.) Click and open MAC or Apple HD / Library / Receipts., and look for "Epson Printer driver package or Epson Printer driver.pkg and drag it toyur trash..
4.) disconnect the connection from your Computer to Printer (USB)
5.) Empty your trash bin and restart your computer
Steps to download printer driver:
1.) Download Printer Driver Ver 3.88 epson12439.dmg
try this link > http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342&prodoid=63069506&infoType=Downloads&platform=Macintosh
2.) Ones it is downladed to your desktop click and open the file or click on the "Vise X Installer" / Install and then quit
3.) Connect the printer to your computer (USB)
4.) Click on the Apple Icon / System Preferences / Print and Fax.,
Click on the plus sign to add the printer and print
Jun 27, 2008 | Epson CX8400 All-In-One InkJet Printer
Printer not printing
Make sure all cables are connected first. You may need to verify that the printed is installed correct by going to control panel and then to printers. Verify the printer is listed. If not you'll need to install it first. If installed and listed. Go to device manager and make sure driver is installed. You might even try to update driver by going to Printer Manufacturer website. Any more info would also help solve. Hope this helps. Thanks
Feb 19, 2008 | Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
