Question about Kenneth Cole RK5034 REACTION
Kenneth cole kc1396
Watch band came apart lost one of bracket and screws at back of watch
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
SOURCE: leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
Posted on Aug 10, 2008
SOURCE: HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
Posted on Aug 11, 2008
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
Need a link for band
  • The original bands for that watch are very difficult to come by. But having a spare part or two never hurt either.
  • Hope this helps.
Nov 26, 2011 | Kenneth Cole KC3289 Wrist Watch
Where can I get a new band for my KS4003 Kenneth Cole watch? The clasp won't open and I didn't want to pay $65 just for a new clasp. How much is the band?
Thank you for contacting FixYa,
You can contact Kenneth Cole for a replacement band but I am afraid the band is probably going to be alot more then the $65 for the clasp. I would honestly just replace the clasp unless the band is worn in which case I would do the band.
Sorry.
KC can be reached at 1-800-KEN-COLE
Oct 02, 2010 | Kenneth Cole Watches
Do you have a watch band for kenneth cole 1363? many thanks
mcdevito75 here, Best Bet, look for a small watch repair shop in your area for a replacement strap for your Kenneth Cole watch.
Jul 13, 2010 | Kenneth Cole Watches
Where can I get replace band for this watch.. I have had it replace twice and the strap keeps ripping out of the screws. Where can I get another original KC band?
mcdevito75 here, Best Bet, see a small watch repair shop in your area, for the new band, You could get an orginal Kenneth Cole band on ebay.
Jun 28, 2010 | Kenneth Cole 1315 Dial Strap Watch for...
Kenneth Cole leater strip
mcdevito75 here, Almost any watch repair shop can supply a new band, look for the small watch repair shops to save some money.
Jun 14, 2010 | Kenneth Cole KC1333 Watch for Men
Watch bands f/ Kenneth Cole
Replacement watch band (f) can be purchased from amazon, take a look here: Amazon com kenneth cole band Watches Women Clothing Shoes Jewelry Wish you best of luck. Cheers
Jun 22, 2008 | Watches
Kenneth Cole Reaction band
Call 7298600 x 272 ask for a free pin for model rk 5033
Aug 27, 2007 | Kenneth Cole RK5034 REACTION
Kenneth Cole RK5034 REACTION Logo
108 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
