Question about Whirlpool Refrigerators
The digital number lights are not working on the inside of my whirlpool fridge. These lights display temp. settings and the actual temp.The inside light bulb is also not working. I called whirlpool to see if I need to change a fuse but there are no fuses in this unit. Not sure if a new bulb will fix the digital dislpay.
  • 57 Answers
Not a bulb. Some of these units have a power board beside the compressor. Need a complete model number located in the refrigerator section.
Posted on Mar 31, 2011
The display stopped showing temps and displayed a "6". The actual temperatures dropped to freezing. I unplugged the unit a few times for up to 2 days but the same issue developed.
Whirlpool Refrigerator Error Code: Flashing 6 on the fridge display
Condition: The 6th Sense technology is activated - If you put warm food in the refrigerator or leave the door open, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Part or Parts: Allow fridge to get back to temp on its own (no parts required)
Whirlpool Refrigerator Error Code: 6 on the fridge display
Condition: Computer error
Check: Remove power for 5 minutes
Part or Parts: If code returns replace mother board
Apr 29, 2016 | Avanti Refrigerators
The temperature in refrigerator is coler than setting on the display why?
Before I begin is the model number=> GI5FVAXVL correct? If not I will need the correct model number to proceed. Thanks, John Tripp Appliance 911
Jan 29, 2014 | Whirlpool GI5FVAXVL (249 cu ft) Bottom...
Whirlpool french door refrigerator
What is your model number? With the model number I can look up the components that may be causing this problem. Example would be a defective thermister or thermostat control. Thanks Sea Breeze
Apr 24, 2013 | Refrigerators
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gs2shexn side by side problem
Hi: It sounds tough. Have you tried resetting the electronics? Unplug it for one hour. Don't get into it so the cold will stay in. Then plug it back in again. Sometimes chips need to be reset. Good Luck, Jeff
May 30, 2009 | Whirlpool GS2SHEXN Side by Side...
Inside light on fridge/freezer not working.
OK, the digital logic being out reminds me of the possibility the mother board or circuit board has gone out. If you can get the complete model number on inside of fresh food compartment door frame, near bottom of door, I will be able to help you better. While I wait I will try to look up similar models and get better answers for you. Thanks, Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE profile fridge
Are numbers being displayed at all? If you want to confirm whether they are wrong or not, try putting a thermometer inside the fridge for about 10 minutes and check it against the temperature displayed. If it's wrong then it's probably the temperature sensor and would need to be replaced.
I suppose it's a long shot but could it be displaying 18 and feels more like 65? (Celcius vs. Farenheit)
Nov 08, 2007 | GE (JASHO96273)
Refrigerators Logo
303 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
