Question about Emerson Audio Players & Recorders
I have a Emerson Model PD6517BL Boombox and keep getting an error message "dn" and the CD will not play.
2 Suggested Answers
  • 159 Answers
SOURCE: I have a Sony" Personal Audio System" /boombox.
Hi, this is a pretty common problem with C.D. players, the laser has lost a bit of its intensity. This possibly can be fixed by adjusting a very small " semi-variable resistor " this should be located on the laser assembly or on the ribbon cable just before the laser. It may be a colored plastic dial with an arrow on the top, or a metal looking screw type looking adjustment ( probably has a bit of enamel to lock in place-this breaks free easily). It may even be labeled " bias ". Use a small phillips jewelers type screwdriver for the plastic kind and a slotted jewelers for the metal. move the adjuster in very small increments one way then or the other if need be. Make note of the original position in case you need to adjust different semi-variable resistors. also its even possible to have a dirty lens, use a jewelers loupe or equivalent to check. a very light touch with a Q-tip dipped in rubbing alcohol should do the trick. use opposite end to dry, be sure to not apply excessive pressure-the lenses suspension is extremely delicate. I hope this was useful-let me know if so or even if not so I may try again. Thanks for asking FixYa-good luck, Prodzilla
Posted on Apr 23, 2011
I bought a used Emerson PD6810 Portable. It plays great but it won't play with batteries and I tested the batteries they are good. Any advice?
check for a switch at the back or pull the power lead out of the jack socket as some machines will not operate batteries and power at the same time
Oct 22, 2014 | Emerson PD6810 Portable CD Boom Box...
How to fix cd player in boombox - freezes briefly before resuming
IT'S CHEAPER TO BUY A NEW ONE THAN TO HAVE IT FIXED...ESPECIALLY AN EMERSON.
Oct 13, 2014 | Audio Players & Recorders
My Emerson 5812 Boombox will not turn on all of a sudden. I just bought it a couple months ago and it will not power on.
If its still under guarantee then take it back to the shop if you have the receipt. If not then it could be something as simple as a little glass fuse inside the boombox.
May 21, 2010 | Emerson (PD5812) Radio/CD Boombox
The cd's will not play. Radio & cassettes are fine. What do i do
Clean the lens and keep your fingers crossed!
Otherwise may need the laser replaced!
Apr 20, 2010 | Emerson PD6537PL Cassette/CD Boombox
Built in Car CD player
get yourself a cd cleaner and clean the cd. then try another cd. if this does not work and if under the warranty take to the shop.
Oct 24, 2008 | Emerson PD6810 CD Boombox
Radio plays sometimes, won't others. is getting power, fm stereo indicator lights up when tuned in to a station, but no sound from the speakers, not even static
maybe the amplifier inside is failing if you turn it all the way up for a second and it comes on then it is the amp but if you wiggle the vol and it comes on the its the vol switch
how did the speakers sound ?
Oct 11, 2008 | Emerson PD6810 CD Boombox
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
61 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
