Question about Samsung Televison & Video
My samsung le40a557p2f won't switch on at all. It started taking longer and longer and now won't turn on at all. It did this once before and Samsung came and repaired free of charge but now it's out of warranty. My nextdoor neighbour has the same TV and has had the same problem. What can I do?
5 Suggested Answers
  • 85 Answers
SOURCE: 6'' Scratch in Samsung LCD TV
THE ONLY WAY I KNOW HOW TO FIX THIS PROBLEM WOULD BE TO REPLACE THE DISPLAY PANEL UNFORTUNATLY THE PRICE IS WHAT THE SET COST ORIGINALLY TRY RUBBING THE AREA WITH A DAMP T SHIRT OR DIAPER IT MAY HELP OTHERWISE I AM SORR FOR YOU
Posted on Nov 14, 2008
SOURCE: Samsung LE40R73BD Will not switch on
I found a fix for this problem on another forum, It's caused by some blown capacitors on the main power board. I have a link to the original post, with step by step pictures for replacing the blown capacitors but don't know if it's ok to post it here. The repair cost me £7.49 for 5 capacitors RS part number 526-1109 and about £4.50 of that was for next day postage. I did the job myself in about 15 minutes and I have no experience with a soldering iron (i even had to borrow one). I replaced 3 capacitors, 2 of which looked blown and one which just looked swollen.
Remove the back off your tv, and just take a look at the small array of capacitors near the top right corner of the centrally situated power board. there are 4 identical capacitors rated at 1000uf 10v 105 degrees C. I think the silver capacitor lids should be flat or even slightly concave. The ones I replaced were all slightly convex and 2 of them had a tiny amount of what looked like brown corrosion right in the centre of the caps.
For a few quid I'm sure you could get someone else to do the soldering if you lack confidence.
The original post also linked to a supplier of the main power board for £130. I didn't mind having a go myself because I figured if I fouled up I could always just buy the board.
Posted on Apr 15, 2009
  • 7 Answers
SOURCE: My samsung tv turns on and off repeatedly at
Mine was doing that then it quit even turning on so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Posted on Jul 09, 2009
dave1645
  • 834 Answers
SOURCE: Samsung 26" LCD TV will not turn on
you have one or two bad caps in the power supply these can like devices will be puffed on the top from venting the value is wrtten on the sides replace them and you will be good to go
Posted on Nov 06, 2009
Samsung red light flashing 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 17, 2016 | Samsung Televison & Video
The router took longer and longer to start once the switch was turned on. Now it won't start at all.
remove switch and disassemble and clean it. mine was full of wood dust , cleaned it and it worked like new again.
Jul 30, 2011 | Bosch 1617EVS 2 Router
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
My samsung galaxy ace gt-s5830 keeps turning itself off. The only way I can get the mobile to switch back on again is to take the battery out and then switch it on again. This has happened twice already...
I also have the exact same problem.
However, you don't need to take out the battery to re-power on the phone. Just hold the power button for a longer time (about 10 seconds). The screen will light up and the device will reboot.
Mar 14, 2011 | Samsung Cell Phones
Samsung 40 inch LCD takes longer and longer to turn on, 5 minutes now, screen black with light under name on; once on line defects appear on screen. Sometimes when turns on only random lines instead of...
common problem you have a bad cap or 2 in your power board this board is the one where tour ac cord plug into these can like caps will be puffed up on top the values are written on the sides on the device replace them and your good to go
Nov 18, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
52" Samsung rear projection TV
Check for CRT coolant leak on PCB's.If minor, clean up spill--try again--see what you have.
Sep 21, 2007 | Samsung PCH521R 52" Rear Projection...
Samsung TXJ2567 long wait for picture
That is usually indicative of a weak picture Tube. If the set is over 8 years old, I would consider replacing it. Otherwise, a repair shop may be able to restore the picture for awhile longer.
Dec 19, 2006 | Samsung TXJ2567 TV
Televison & Video Logo
56 people viewed this question
Henry  Thomas
Henry Thomas
