Question about Home
I have moved into a property with a Sector extractor fan in the bathroom - when you turn the light on the extractor starts up -when you turn the light off the extractor continues to run for a long time - how can I turn the lenght of time the fan runs for down
    Problem Solver:
  • 20 Answers
On some Bathroom extractor fans there is a setting for the amount of time you want the fan to stay on after you turn off the switch, the setting dial is normally at the back of the fan so you need to take the fan down from the ceiling making sure the fan is electrically isolated.
Posted on Apr 01, 2011
    New Friend:
  • 17 Answers
Yes there are usually one or two little knobs on the fan itself which can usually be turned by using a small screwdriver or your fingers. You would need to take off the front cover of the fan and look for these little knobs. If there is only one, then that will be the run-on timer. If there is two, then one will be the run-on timer and the other for setting how damp it needs to get for the fan to come on (if your fan has a humidistat)
Please isolate the fan from the electric supply before attempting ANY work on it.
Posted on May 20, 2016
My Marley extractor fan in the bathroom has stopped working, how to investigate the problem and find a fix
Chances are the motor has burned out. Fans are quite cheap and not worth repairing.
In the UK you can get a complete replacement fan from Screwfix for under £20.
Turn off electricity at consumer unit and remove fuse / turn circuit breaker to off.
Undo screw and remove front cover from the fan. Carefully disconnect wires, remove fixing screws.
Follow instructions included with new fan
Feb 21, 2011 | Home
Hi I have an alto extractor fan in my bathroom but it doesn't activate when I turn on the light. Any ideas on how to fix it? Thanks
you may have a fan operating from purely from a built in humidistat instead of being operated from the light switched . If that is the case an electrician may be able to alter the wireing to have the light switch overide the humidistat, or even adjust the integral humidistat to a lower setting and operate the boost at a lower relative humidity level.
Aug 15, 2010 | Heating & Cooling
My bathroom fan will not turn itself off, it is connected to the bathroom light, light is turned off but fan goes continuiously??????
Then it is not connected to the light switch as you think. This could be a dangerous situation, and you should have an experienced electrician look at it.
Mar 02, 2010 | HP Extractor Fan Kit 110V Rack Mount Fan
I hv a bathroom light incorporated in with the ceiling extractor
I would like to help you with this, But with out looking at the light/fan I can't. So what you can do is find the make and model of the Light/ Fan go to there website and email there tech support. # 2 go to Home Depot and ask someone that works in the fan area to help you out.# 3 If you like email me a picture of the fan/ light in four different places, and I'll be able to help you out. j-zubiate@hotmail.com. My name is Jason
Nov 04, 2009 | Dryers
My Bathroom Extractor Fan does not work properly and for some reason the bathroom smells of cigarette smoke when the upstairs neighbours are at home!! Our landlord say's this is not possible!!!
Yes, very possible!. The bathroom fan is connected together, and the upstairs one is down-drafting to you. Have the exhaust checked for blockage, or buy a fan that has a built-in damper that closes the exit when not in use.
Oct 21, 2009 | HP Extractor Fan Kit 110V Rack Mount Fan
Bathroom extractor fan won't switch off
The fan most likely is turned on by the bathroom light switch. You likely have a defective fan motor.
May 01, 2017 | Hampton Bay 24002 Ceiling Fan
Every winter water drips from my bathroom ceiling mounted extractor fan, worse when there is bad condensation. The vent goes straight up and up through the loft space and out of the roof, there appears to...
condensation is created by 2 exteme temperature change.
looks like the loft space is colder than the rest of the house.
first make sure there is not blockage in the vent. then warp the vent with fiberglass as much as you can. it doesn't matter what R value the fiberglass is. just enough to cut the temperture change.
you still going to need a exhust fan in the bathroom.
Oct 31, 2008 | Hampton Bay 24002 Ceiling Fan
Wireing a bathroom extractor fan to a three switch (fan=landing light=offswitch0
yes, if the three switches are all made together, then there is only one feed. sounds like a bad switch, or possibly bad exhaust fan. check voltage at fan with switch on, if not qualified, be careful, or call an electrician
Aug 10, 2008 | Dryers
Home Logo
936 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
