Question about Zebra Z4Mplus Label Printer
I have a Zebra Z4M Plus using Bar One Pro Plus v6.0 I have a label with a text field where that field is not printing completely. Even though text above and below it print fine
  • 2,427 Answers
From what your describing sounds like its 1 of 3 things,
firstly, take the paper out and let it warm up in a light cupboard or under a florsecent light, let it heat up a bit and then replace it in the printer. try printing now and more than likely it will print. Reason being is that the paper has moisture build up on it, keeping new paper in a warm dry place will help with this. If this wasn't your problem then lets try the next thing.
purchase and replace the platen roller, more than likely part of the roller is damaged (the part that your text label falls on, replace it. you can also redesign the lablel so it falls on another part of the label.
Posted on Mar 31, 2011
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Why would bar code print both vertically and
This is I think due to the data being sent to your printer. On a Z4m the width is 4 inch and whatever is beyond is not printed. On your Z6M the coordinates are valid so your printer will print the code.
Mar 26, 2010 | Zebra Z6M Thermal Label Printer
Using multiple printers on switch box. Z4M Plus and Z6M. Sometimes data is missing or printed incorrectly. Font size changes or certain text is missing. We are using Label Vision Version 4.3. It is like we...
The problem with this type of printer is that when you use true type fonts, they are downloaded as graphics. If you have a field which changes on each label there is an overflow of memory. The solution is to use internal fonts for continuously changing datas
Oct 08, 2009 | Zebra Z4Mplus Label Printer
Zebra Z4M Plus
Is the length of the label correct on the configuration print out?
Else try t check if there isn't a feed or print adjust in the parameters
Jun 25, 2009 | Zebra Z4M+ Printer
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Slow Printing on Zebra Z4M
An unorthodox solution is to install an old driver. Another solution is to use with Codesoft the driver from www.seagullscientific.com, and with Zebra Designer, the Zebra Designer driver. If the printer is connected to the serial port, speeds up communication.
Roberto Martinez
Mar 30, 2009 | Zebra Z4M Printer
Zebra 4M Plus
What software are using? If you use or Zebra Designer Label Matrix, uses its own drivers. If you use another driver, verify that the graphics option is "dithering".
Roberto Martinez
May 20, 2008 | Zebra Z4M Printer
Zebra Z4M Plus
this is a color printer or not
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra Z4Mplus Label Printer Logo
124 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
