Question about Carrier Heating & Cooling
I have carrier infinity 18 central air and worked good for one year and second year summer season its out of purion gas and we had an authorized person to recharge with purion gas and worked for a few days and back to old problem and now found the condensor is leaking and condensor pan is cracked and found out service personnel says there are many carrier infinity with these problems. I have been fooled by inferior carrier product and would like to form a group with people with similar problem Can you help me how to resolve this problem or to discuss with others with similar problems
  • 182 Answers
Carrier carries a 5 yr parts warranty.I'm not a big Carrier guy but the are not an inferior product from what I've seen.I'd contact another company that is a Carrier dealer for a second opinion.
Posted on Aug 05, 2008
SOURCE:
Wat is buenos aires klimaat
Buenos Aires, the capital of Argentina, has a temperate climate, which is classified as a humid subtropical climate (Cfa) under the K?ppen climate classification with four distinct seasons. Summers are hot and humid with frequent thunderstorms while winters are cool and drier with frosts that occurs on average twice per year. Spring and fall are transition seasons characterized by changeable weather. At the central observatory,[note 1] the highest recorded temperature is 43.3 °C (109.9 °F) while the lowest recorded temperature is ?5.4 °C (22.3 °F).
Feb 04, 2018 | Cars & Trucks
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 17, 2010 | Heating & Cooling
No Cold Air
it sounds as though the compressor is stalled or seized. if its seized a new will be required! If its stalled it may be down to a failed capacitor, if you have a voltmeter test for voltage at the compressor.
When shutting off leave it off for a good 24 hrs
All the best
Jul 05, 2010 | Danby DAC5071M Thru-Wall/Window Air...
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Carrier 58mvp furnace ecm motor is making viberating noises
ecms are pretty reliable and electronic failure is much more common than bearing or bushing wearout. i suspect the fins on the blower may be coming loose from their pressed on spline and that will start a vibration or shimmy or you could have thrown a weight that balanced the wheel . best to use to warranty to get a new wheel. good luck
Dec 07, 2008 | Carrier 38CKC036 Air Conditioner
Burners wont ignite
does unit have thermo-cupling
Nov 23, 2008 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
577 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
