Question about HP Officejet Pro L7480 All-in-One Multifunction Inkjet
Hello, i have a HP Officejet Pro L7480 which did not cause trouble for 3 years, but now: PROBLEM WITH PAPER FEEDING - when trying to print something, the printer normally "tries" to grasp a paper 2 times and tells "no paper insde/put paper inside" if it failed the 2nd time - more and more the printer started to miss feeding the paper, so I always had to push "OK" for having put new papers inside, which i did not, because ther is already enough... but then it printed at least (so to say feeding the 3rd and 4th time, because firstly there was a little advance towards moving the paper ...) - meanwhile it is almost impossible to print; mostly, when the printer tries twice, the first time there is no feeding progress, the 2nd time there is a little and no matter how often i repeat the "OK" it wont print at all (respectively 1 out of 20) - i cleanded the rollers with alcohol but then i saw that the papers dont even make it to the line of rollers on the back there is one single bigger roller which moves down on the papers where they are being put, i cleanded this one, too; it is not defect, but... - maybe its "weakened" somehow? - or doesnt work proberly feeding the first time? Also i saw that the rollers on top, which move the already printed pages at last, are being cut, probably to provide better grip? I did not see that alle the other ones on lower height are cut similar way, is there some damage? Hoping for Help :-) Justus.
  • justus_saeng Apr 11, 2011
    is there no way?? software - hardware, whatsoever?
    Genius:
  • 1,570 Answers
Hi
If it attempts to feed and expecially when you hear a cricking sound. It means that the paper guide it too tighten that it holds the paper. Try to loose up the paper tray guide. Are you using a paper tray. If not, put small paper or change the correct setting of the paper size setting to auto detect if any.
The try to print again.
Posted on Mar 31, 2011
  • 6 more comments
  • justus_saeng Mar 31, 2011
    Hey benjz,
    thanks for the really quick answer first.
    I dont know if i understand you exactly, i am not really an computer expert and i dont know exactly about specific vocabs ...
    By a "paper guide which is to tighten" respectively "loosing it" do you mean the two artefacts on left and bottom side of the paper guide, which are used to put the "frontier" of the paper size? (i have a paper guide, which is on the bottom of the printer in horizontal direction to the ground, like on the picture in the left upper corner)
    If yes, I tried this, i even put those two regulation artefacts to maximum extend, so they dont have any contact to A4size paper (normal size) anymore - still paper feeding does not function properly.
    The only other thing, which might be to tighten could be the roller which moves down on the horizontal paper, or not? I dont know how to loosen this one, if its an possible option ...
    Thanks in advance for further suggestions,
    greets,
    Justus
  • Benjamin Jr Singson Mar 31, 2011
    Yes, you have to loosen it. But try to use the other tray and it is located above the paper tray. if not printing the lower paper try.
    Sorry but you don't aswer my question if the printer roller is moving and it attempts to pick up a paper into the paper tray. try to put 10 pcs paper. Check also in printing properties the correct paper size like A4 as you mention. because may the sension detecting incorrect paper size.
    hey, i have looked - by flashlight - at the roller which comes down for the paper feeding and its not spinning, how can i loosen it? The paper size of the printer is set to A4 and i also tried only a few papers around 10 without success.
    If the roller is not spinning, it is probable not a feeder roller issue. Can go to printer icon and check if there are pending printing jobs and delete them all.
    Also follow this procedure.
    Go to START MENU
    Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32 and press enter")
    Type the letter "cmd"
    Type the word "net stop spooler"
    Exit
    Go to C: drive
    Choose to Windows Folder
    Click show content
    Choose system32 folder
    Choose spool folder
    Choose printer
    And delete all printing jobs pending
    Again go back to CMD window and type the word "net start spooler"
    Restart your computer and must also turn off your printer and then switch it on.
    If still not working, try to set up once again the printer and print the test page.
    thanks again, but i am quite sure that it must be a feeding issue ... since the HP is also a copier i tried everything by coping (not printing from pc, therefore it cannot be a software problem ... so the hardware of the HP always stars scanning the page and than the paper feeding starts (roller moves down and sometimes it spinns a bit ... and 1 out of 20 times it spinns enough to make it to the printing process ... )
  • Benjamin Jr Singson Apr 01, 2011
    Scanning is different because you use only the photo bulb light when copying. We need to consider some causes aside from feeder sensor issue. Try follow some solution I suggest and I will give more until we find out what causes your printer not printing.
  • justus_saeng Apr 03, 2011
    i did everything (cmd, reinstall, etc. ... ) it really does not matter if I copy or print from PC (I also can do testpages directly from HP..)
    it is always the same .. papers are being feeded not enough or not at all ... i just did and test page (from printer, after reinstallatino and without any pending printing jobs) ... it told me three times theere is no paper ... i always said "ok""ok""ok" and every turn the paper moved/feeded a bit further till it printed ...
My paper feeding is crooked
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
May 15, 2016 | HP OfficeJet 7310 All-In-One InkJet...
Paper jam--how do you pull the paper out?
Please open this LINK and follow the instructions. You'll also find some helpful tips about Paper Jams HERE.
Hope this will help.
Good luck.
Thanks for using FixYa.
Aug 03, 2011 | HP L7480 Officejet Pro MFC All-In-One...
I have got an HP OFFICEJET PRO L7480 (All in One) and a problem with the paper feeding. I tried all the usual things (resetting, cleaning rollers, etc.) It seems like it is mainly a problem with the...
the problem in your printer could be the plastic gear attach to the end of the rubber roller that grabs the paper. Look closely and see which gear's teeth is broken or already worn out. This cause the delay in the timing of the rotation of the roller.
Check also the mechanical timing of the roller. if you can unlatch the tension spring / lock to make the rubber roller moves freely, do it....position the rubber that grabs the paper, try 90 or 180 degrees from its previous location.
Hope this helps!
May 10, 2011 | Office Equipment & Supplies
I have had this printer for almost two years and the Document Feeder has never worked. It is getting tiresome. I have cleaned the rollers and the paper feed but it still jams when I try to feed a...
Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts, you can actually get a brand new printer half the price that you will see on the website plus you can also get an extra year of warranty just by adding $1.00 to the total price of the printer.
Feb 13, 2011 | HP Officejet Pro L7480 All-in-One...
Hp Officejet L7480 false paper jam message. Resetting the printer has no effect.
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
May 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Hp L7480 Keeps printing an alignment test page everytime it is turned on. I now there is a key, something like # something that stops this from happening, I read it somewhere and fixed it the last time it...
I suggest that you uninstall the device and unplug it from your computer, then, use the installation disk and re-install the drivers, then plug er right back in.
You shouldnt have to have the print test page at bootup or startup every time...
Apr 05, 2010 | HP Officejet Pro L7480 All-in-One...
Hello, I have an HP Officejet Pro L7580 All In One printer. Sat for 2 years. Barely used when purchased 3 yrs ago. Just hooked it up again. Replaced all ink cartridges...now prints are very pixelated and...
Try doing running it through it's aligment process.
It is also possible that the contacts where the ink cartridges mate up with the printer are corroded. Try using an eraser to clean the corrosion off the mating surface in the printer.
Jan 22, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I am trying to print envelopes using HP Officejet Pro 8000. I don't see an envelope guide and the envelopes are skewing when feeding. Is there an easy solution here?
If the tray is similar to a Officejet PRO 8000 that I have,REMOVE the stack of paper, bring the adjustable guide walls towards the center, and you should be able to print envelopes.
Oct 30, 2009 | Office Equipment & Supplies
When I go to scan it tells me 'no scan options'. Have I bought a very large printer only?
According to the model specification the HP Officejet Pro L7480 is a scanner and a printer http://h10010.www1.hp.com/wwpc/uk/en/sm/WF06b/18972-18972-238444-3328086-3328086-3446481-3446611.html plese check this link and confirm the model etc. Also do check if you have installed all the drivers and softwares required properly.
Jul 05, 2009 | HP Officejet Pro L7480 All-in-One...
HP Officejet Pro L7480 All-in-One Multifunction Inkjet Logo
196 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
