Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Refrigerator light will not turn off. Replacing both door switches did not help. There is a sensor listed as parts but I can not find location to replace. Bulbs became so hot as to melt the plastic rim.
  • 2 more comments
  • rsasds2 Apr 03, 2011
    The two door switches out of the connector both show the switches to be working. ( ohms are 1 with switch depressed and .02 with switch out.) Yes, if both switches are disconnected the light does go out.
    Where to now?
    This is a kenmore elite model # 795.77242601 made 2007.
    Thanks
    Where to now?
    Thanks
    See prior comment 4-2-11
  • rsasds2 Apr 09, 2011
    Both new and old switches work but light still does not turn off. Disconnecting the light switches does turn off the light from the top of the inside refrigerator. The light on the front water dispenser still turns off and on as expected with the light unplugged and the light switches on hinges attached.
    Could this be the circuit board on the back as someone else blogged?
  • 4,070 Answers
If you disconnect the door switch does the light go off. If yes, test switch with an ohm meter to see if their is continuity between the plugs when you depress the switch.
Posted on Mar 31, 2011
  • Charles T Nevin
    Charles T Nevin Apr 03, 2011
    One of the switches is allowing voltage through it. Test the voltage on each switch with the switch depressed and see which one is allowing voltage through.
I have a Fisher & Paykel E522B refrigerator that appears to have seems to have a faulty door switch. The refrigerator will beep even though the door is closed. Where is the door switch on the E522B?
I can only find the switch for the bottom door; but perhaps they've just not listed the one for the top; but, it should be in a similar place.
It's parts #17 & 18 here: Model e522brx21639f FISHERPAYKEL REFRIGERATOR Parts
You will see where they're located on the image.
Hope this helps.
Jul 04, 2017 | Fisher Refrigerators
How do I replace the door light switch?
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Apr 27, 2015 | Frigidaire Freezers
The interior lights wont turn off. they melted the old light bracket so i replaced it and the lights still wont go out
It sounds like you have a switch that isn't closing when the door shuts. I'm not overly familiar with the LG's, but looking at the Sears Parts Direct site, it looks like the door switches are in the hinge covers on top of the unit. There should be two of them, one for each door. But, only one has to not be working to keep the light on. The first thing I would check is to make sure the hinge cover isn't loose or out of position. The switch should close when the door closes. If the hinge cover moves, then the switch won't close. If everything is tight and aligned, then one of the switches is bad. That can be checked with a volt meter that does continuity checks. Unplug the unit before checking because those wires should be hot at all times. If you don't have a meter and want to do trial and error, just buy one switch since they both are the same. Here is the parts diagram showing the switch locations and part numbers:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LFX25960ST/3204/0161000/K0810255/00001
The switch is 402A on the diagram, located on top of the box. If you click on the parts diagram, you can enlarge it to get a closer look.
The switch part number is 6600JB3007E
Hope this helps
Aug 11, 2011 | LG LFX25960ST Stainless Steel French Door...
The lights in the refrigerator suddenly stopped working even though the refrigerator is running. Tried replacing the bulbs, it is not the bulbs. Why would the lights stop working?
Dear espa8,
I'm sorry to hear that the lights in your Sub-zero unit are not working. It is unlikely that all the bulbs went out at the same time. You most likely have a bad light switch. If you open the refrigerator door & look upwards you will see two white switches. The switch on the left controls the lights. The part number to this light switch is 7014646. We can supply you with light switch replacement instructions if you contact us directly. Make sure that you turn the unit off at the circuit breaker before changing the light switch.
To find a Factory Authorized Service Company in your area please use the link below. Enter your zip code, select 'Service, Repair and Parts', choose a mileage radius, and you will receive a listing of all Factory Authorized Service Companies that meet your requirements. A Regional Parts Distributor can also be found via this link if you would like to order the switch or bulbs.
http://www.subzero.com/locator
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Feb 02, 2011 | Sub-Zero 690 Side by Side Refrigerator
Cabinet not cooling, when i go through the test sequence the cabinet works perfectly the display shows all lights illuminated is this a sensor fault and if so where are the sensors?
The lights inside the refrigerator are not turning off when you close the door .
The light switch is broken. replace the door operated light switch.
Nov 26, 2010 | LG LRSC26920TT Side by Side Refrigerator
Hello, I have a GE Prolife side by side refrigerator PSF26PGSA BB and I notice that the refrigerator side has ice build up on the back wall of it in the inside. Can you please help, could it be the...
Where exactly on the back wall of the fresh food compartment(refrigerator) is this ice build up? If its building up in the air vents, that usually indicates a warm air leak, and this additional warm air is creating condensation, read ice, where it meets the colder air. There is no defrost heater or sensor in the refrigerator, all the cooling components that need to be inside the cabinet are located in the freezer. To check for warm air leaks, check to see that your light switch turns the light(s) off, check that the door actuates the switch when its closed, you will have to close door and squeeze part of the gasket to see if the light stays on. Furthermore, check the door gasket itself, make sure there are no gaps, rips or other malformations. Check that the bottom part of the gasket is not sagging, or the hinge side corners are not bunched up, or stretched out from the corners. Also, let the door close by itself like normal, and check the lower portion of the non hinge side of the gasket, if there is a gap here, further check for scratches on the bottom inside liner, not the door, inside the bottom of the fresh food compartment. If there are scratches here, this indicates the door is rubbing on the bottom because its too low, indicating a problem in the lower door hinge area. You dont mention any refrigerator freezer temperature problems, so it does not sound like a defrost problem or an issue with an evaporator fan motor failure.
Nov 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Door sensor is not working, inside light stays on
This may be a simple switch with corroded contacts. Try this:
Locate the button that controls the light and depress it fully, then let it fly out, snapping it several times to see if it will clean itself up.
If not, it will have to be replaced and this with varying degrees of difficulty depending on how it is mounted.
Since it is a Sears brand appliance, go to the Sears parts department on line and enter your model number. Nearly all Sears/Kenmore appliances will be listed (among with many other brands) and there will be an exploded line drawing of the device that will help you locate what must be removed for this replacement. You can also order that part while you are there if you decide to replace it yourself.
Feb 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Light stays on when refrigerator door is closed
If you can find the 'Plunger" for the light switch......push on it to see it turns off the light. Once you know that is working you can add a "shim" to the door with a piece of tape. But if the plunger isn't working nothing else you do is going to fix it.
The plunger is usually located somewhere on the fridge on the same side where the door hinges are
Jul 07, 2009 | Viking VCSB483 Side by Side Refrigerator
Refrigerator temperature can't be set to cold - sensor light shows 9C and keeps on beeping. Samsung model RB1855SL
I had this exact problem with my 4 yr old Samsung RB1855SL refrigerator. BTW, the temperature display doesn’t display higher than 9C, even when its warmer inside. The fan wasn’t turning on to circulate the cold air, although the cooling coils were still cooling. There was no excess ice build-up. The freezer was working fine.
I thought perhaps the fan was toast or the temperature sensor. Then I noticed the interior fridge light was not turning off when closing the door (but the freezer light was). BINGO—thig light switch was the problem. A small piece on the inside of the fridge side of the switch was broken. When the door was closed, the broken switch didn’t let the fridge know that the door was in fact closed, causing the door alarm to keep beeping. This must shut the fan down in order to save energy when regularly opening the door.
DIY fix: I removed the switch (until I could get a replacement) which is located to the left of the lower door hinge (right hand side). Gently, with a flat nose screw driver, I pried it out.
The light no longer turned on when opening either door but that was a small price to pay compared to the incessant beeping and rotten food. The part can’t be very expensive and I can replace it myself. The local appliance repair shop will order it for me.
No expensive “internal brain” needed to be replaced or an expensive repairman needed to be called. Good luck!
Aug 17, 2008 | Samsung Heating & Cooling
Light Switch Stuck
This is a replaceable part. A new switch can be ordered from Sears by Model number of your refrigerator and name of the part. If you have your owners manual it may contain a list with part numbers. Some of these switches will pop out to be replaced. Others you may have to remove the breaker strip where it is mounted to remove the switch by compressing the snaps on the side of the switch.
May 07, 2008 | Kenmore 60721 Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
