Question about Eljer Whirlpool In-Line Heater- 494-1550-00
How hot should the water in my whirlpool tub get with the in-line heater working?
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
Heater
Water heater can be added to any incoming water line, either on hot or cold.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Under-counter water heater located near tub will supply hot water just like ordinary household water heater. But it will not reheat water that circulates inside the spa tub.
Otherwise, a spa heater is made with electric element that can work with 120V or 240V. Water from tub circulates through tank that holds element. Element must be fully immersed in water.
To retrofit spa tub with this heater would require cutting water line near pump, running both ends of water line into tank with element.
Then of course you would need to retrofit adjustable thermostat to control when element is on. And integrate element operation into air control switch at tub that can override thermostat so element is not heating when tub is not in use.
Unless there is a pre-packaged kit to retrofit heater, I think adding heater would be difficult.
Jun 05, 2013 | Maax Crescendo - 100085-000 Bathtub
Jacizzi tub and water is not hot enough
When filling the tub if there is not enough hot water to fill the tub you will probably need a bigger water heater.
You can add a Bath Heater to your tub if the water is cooling down too quickly while you are using it however, a Bath Heater will NOT heat the water. They will only maintain the water temperature you start with.
Rod
US Parts Center
888-521-6183
Jan 08, 2013 | Home
Bought a hot water heater made by whirlpool for 2 weeks only had enough hot water to fill 1/4 of the tub then the water turned cold . They have replaced the hot water heater and still has same problem....
The down tube in the tank has fallen off or the hot and cold lines are reversed at the tank. I'm going to assume it is gas , if its electric you need to test the heating elements for continuity and temp settings. as well as the down tube in the top of the tank that sends the cold water feed to the bottom of the tank..
Mar 13, 2011 | Whirlpool Home
Is it possible to install a small on-demand hot water heater in lieu of an in-line heater for a jacuzzi, so the pump will circulate the water through it? Is there a benefit to this?
Hello, I not sure if your having a problem with your current in-line heater and can't get to it to repair or replace it but, this is the most effective way of heating your tub water without adding water and I say this assuming that the heater is 220 volt and not 115volt. An on demand electric water heater would cost more money to operate then your current unit. A gas on demand heater would not function properly and would fail to provide the hot water you need. If you install a gas on demand water heater and use it to just fill your tub with hot water then you would save money in the long run and be able to use it for your whole house. Hope this information is helpful. If you have more questions please feel free to ask.
Feb 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
There is no hot water after we installed
If you currently have hot water coming to other parts of the house, and you have patiently waited for the hot water to reach the tub, then you don't have a hot water line connected to the faucet. Also, because a hot tub or whirlpool can hold more water than your water heater holds, an inline heater is often used. It attaches to the plumbing system on the whirlpool.
Dec 24, 2010 | Home
I have A whirlpool hot water heater I can get hot water downstairs but not upstairs through the shower and tub
Upstairs do you get hot water to your sink faucet. If you do this indicates to me that the temperature valve in your Shower & Tub may need to be adjusted.
For single handle please remove handle to gain access to dial that adjusts hot & cold water mixing.
Remember where it is and take it out and replace about a 1/8 to 1/4 turn counter clockwise and reinstall and try.
It is a plastic adjustment dial that will slide off after the handle is removed.
Trace lines if possible to assure correct pipe's are connected to valve.
May 20, 2010 | Home
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Need to heat water up more
I had same problem... fixed by turning hot water tank up to 145 degrees...but PLEASE do not do this if you have young children..that is hot and will burn!.. but does work(did this 8 years ago!)
Mar 15, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Eljer Whirlpool In-Line Heater- 494-1550-00 Logo
60 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
