Question about Acer Aspire 5630 Notebook
How to setting the brightness in my laptop acer???
  • 85 Answers
Normally you can change this by holding the FN key and pressing F5 or F6. This may vary depending on your model vs mine. look for a smaller and larger sun icon on the F keys.
Posted on Mar 31, 2011
Acer aspire 5734z laptop
Lots of laptop have power profiles that switch when either AC is plugged in or removed.
There should be a memorized screen brightness setting in your power management options. Usually it's located in the built-in Windows settings under Control Panel -> Power Options -> Edit Plan Settings.
You should see a brightness slider for the screen for "On Battery" and "Plugged In". Pick your brightness from there and it should stick.
Another way is to use the "FN" key on your keyboard. Hold down the FN key and press the associated brightness picture, which on your Acer, should be the RIGHT and LEFT arrow keys. Keep holding the FN and tap the right or left to increase or decrease the brightness. Usually the setting will stick this way, but somethings you have to use the control panel method for it to really stay.
You also might have another program for power like Acer ePowerManagement which should have the same settings as windows, but layed out differently.
Nov 18, 2013 | Computers & Internet
Dark picture on monitor
Occasionally, you may find your laptop's monitor is too dim for your liking. A normal desktop computer's monitor has an on-board menu system that lets you adjust the brightness and picture control settings as you please. A laptop monitor has no such controls. You can adjust the brightness of your laptop monitor using your laptop's keyboard.
1. Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2. Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3. Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4. Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful. Thank you for using fixya
Aug 17, 2011 | Acer Aspire 5610-2089 Notebook PC (ACER...
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
When laptop accer not plug (battery full charge) the screnn does not look bright
The power/battery settings are set for powersaving, rather than performance, so the battery lasts longer. If you set it to performance, the screen will stay bright.
Mar 18, 2011 | Acer Computers & Internet
How do i turn the brightness down
Right click anywhere in the blank area of the screen then click on properties the following screen should come upcomputer254_5.jpg
then click settings tab should then see a screen similar to this
Then look for your Graphic card properties for example after clicking Graphics Properties tab the following screen should give then the opportunity to change your settings
The above are some examples taken from my aspire desktop but should help you further resolving your problem with brightness
Hope this solves your problem
Mar 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
My acer netbook screen is always dim even when it is plugged into the wall
adjust brightness settings on most acer laptops u hold the FN key and press one of ur arrow keys quite often the left and right for brightness up and down hope this helps
Mar 11, 2010 | Toshiba Satellite 5205-S503 Notebook
Acer aspire 3000 display dim can i make it brighter?
You should be able to adjust the screen brightness using the "FN" key and the keys that have a sun on them with a arrow up and down. Or you can right click on the desktop and change the screen's brightness in the display properties. And sometimes laptops are set up to automatically lower the brightness when the power properties are set to power saver...like when running on batteries only and no ac power connected.
Nov 23, 2009 | Acer Aspire 3000 Notebook
Cant ajust the brightness
there is usually a Fn button in blue. then every Fn is designated on a corresponding key. Hold the Fn key and look for a sun with an arrow up, and one with sun & arrow down. Adjust accordingly.
Dec 22, 2008 | Acer Computers & Internet
Acer 4315 laptop Screen very dull.
hi dear,
Try to reset the Bios settings on the laptop... dont worry.. shutdown the laptop restart it and press F8 on the key board.. continuously... Once you are at the Bios and Cmos settings find a way to reset all the settings to default...
Was i helpful?
Nov 18, 2008 | Acer Aspire 4315-2490 Notebook
Low brightness
If your Acer shipped with a "notebook manager" in the Acer folder, check the display settings tab. Look closely at the bottom, there is a slider that will adjust settings if your fn keys are broken, like mine. Again, look carefully because if the slider is all the way left or right, you hardly notice the functionality at all.
Mar 08, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5630 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
