Question about Homelite Garden
My Homelite 330 always runs fast without the trigger being depressed. It won't idle down. What might it be?
  • 316 Answers
SOURCE: 1997 dodge 3.5 fast idle can not slow it down
Sounds like a vaccuum, or gasket leak. Easiest way to diagnose is to get a can of starting fluid and spay it around any vacuum hoses and intake area while it's running. Be careful! Starting fluid is extremely flammable!
If you notice an acceleration, or de-celeration while spraying the starting fluid, you should be able to pinpoint the leak.
Posted on Apr 17, 2009
SOURCE: homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Posted on May 09, 2009
panilling9
  • 284 Answers
SOURCE: Problems with my HomeLite UT20760 bogs down, no power
try this
you need to locate your muffler and find screws that remove a screen behind a plate you can remove on the muffler or behind the muffler itself
This screen is a spark arrestor screen and needs to be cleaned and put back or some would say discard all together, but i didnt say that.
give it a look see
this may be your problem and maybe not?
if it was you will see a trmendous difference afterwards
Posted on May 31, 2009
  • 4 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
did you try fresh gas
#1 Taper
  • 1040 Answers
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Posted on Jun 02, 2009
Poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
remove the muffler and try it if ok open the muffler and clean out the carbon from the screen
Apr 06, 2012 | Poulan Garden
The fast idle button on my Poulan 2050 is stuck down all the time. I assume it should pop up and lock into place when depressed. I can get a total replacement part, with pins, no problem. How do I...
The trigger and lock out lever comes as a kit, part no. 530071305, remove the top cover, depress the trigger and pry up the throttle wire away from the trigger, knock out the two roll pins, drop the trigger out of the bottom of the handle, lift the throttle lock out of the top of the handle.
Oct 27, 2011 | Garden
I have a Homelite Trimmer Pro Series PBC 3600. I have replaced the carburetor and all fuel lines.The unit cranks runs fine at full throttle and at a fast idle, but I can"t idle it down enough to stop...
I have a Homelite Pro Series PBC 3600 and need to know what blade with work as replacement blade? I ask this because homelite has gone out of business as I have been told by Lowe's and other businesses here.
Aug 23, 2011 | Garden
I was using my Homelite 330 and it quit running.Now when it starts it runs at a high rpm for 5 seconds or so then winds down and stops running. I've checked fuel. The local repair shop won't even...
dO  tune -up.Here is a link : www.ehow.com/how_6971799_homelite-chainsaw-tuneup-instructions.html also visit www.homelite.com/ for more.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 07, 2011 | Homelite ZR10926 16 Chain Saw
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Can anyone help with fuel mix and starting instructions for McCulloch 2214av chainsaw please
Ok, always use good quaility teo stroke oil, from a manufacturer who actually produces a chainsaw, ie Husqvarna/Stihl/Jonsered etc, all of these oils should be run at 50-1, avoid oil makes you have never heard of.
Starting instructions are as follows, switch the red ignition switch too on ( up ) depress the primmer bulb as many times as it takes to 3/4 fill the bulb ( you cannot flood the engine if you over prime, it is better to over prime ) pull the blue choke fully out, crank the engine until it fires once ( it will only fire once, do not continue to crank the engine after it first fires with the choke still out ) now push the choke fully back in, crank the engine until it fires up and runs on fast idle,now blip the throttle trigger to diss engage the fast idle position, the saw should now drop down to idle.
Regards
Jan 31, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 09, 2010 | Homelite ZR10926 16" Chain Saw
How to stART HOMELITE 18 INCH TIMBERLINE
Make sure you have fresh fuel mix in the tank. Pump the primer bulb about 6 times or less until the bulb draws fuel into it. This fills the carburetor with fuel. Close the choke and set the fast idle if the throttle trigger has a button near it--otherwise, operating the choke auto-sets the fast idle. Don't operate the throttle again until the engine is running. Turn on the ignition switch and pull the engine through smartly. It should start within several pulls. If nothing happens, then get back to us for some troubleshooting help. Hope this gets it running!
May 07, 2010 | Homelite ZR10926 16 Chain Saw
Its running too lean..there is a plastic cover over the carb adjustment screws
That may be to keep dirt out. One of the screws should be for the richness setting and the other for the idle speed.
Adjust the richness setting so the tool runs the best (fast) then turn the idle speed down to normal.
Make sure you always keep the air filter cleaned or dirt will get into the carb and cause you to have to clean out the jets in the carb.
Nov 07, 2009 | Homelite Consumer Products Backpack...
Garden Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
