Question about GE JVM1790SK Convection/Microwave Oven
I have a GE Pofile JVM1790SK 01 microwave/convection over mounted over my cooktop. Even with the vent on high, it just does not pull. You can hear it going. You can feel blowing outside at the vent, but the whole kitchen smokes up if we cook steaks on the cooktop.
  • 1 more comment
  • lgayvert Mar 31, 2011
    I mean, if I am boiling water or cooking steaks on the cooktop, the steam or smoke is not being pulled into the vent. It just rises up and fills my kitchen with said steam or smoke.
    Daniel, I have taken the filters off to see if it works better, but it makes no difference. it has NEVER worked properly---not from the day it was installed 2 years ago.. The contractor that installed it has fallen off the face of the earth. But, I don't think he knew how to fix it. He tried and it never pulled any better. He blamed it on the appliance---said his doesn't work well either. But, I think the same person installed them and the problem is in the installation.
    It is the GE Profile JVM1790SK. The vent fan is internal. There are two vents under the microwave which are suppose to pull steam/smoke from the cooktop below. It is vented up through our cabinet and out to the back of the house.
  • 4,323 Answers
Hi
Please elaborate the issue and tell me what you mean by it just does not pull. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 31, 2011
  • 2 more comments
  • Daniel Scott
    Daniel Scott Mar 31, 2011
    have you already tried cleaning the vent
  • Daniel Scott
    Oh....somebody didn't do his work correctly and now you are paying for that...anyways do you have the model no for your Vent hood or it came with this unit
  • Daniel Scott
    Sorry for late response....was checking its parts....you will have to take it apart completely to check the issue...I believe it can be the circulation motor that is bad however, as these parts are usually covered under 3/5yrs warranty so its better to contact the manufacturer and get this done. Please check these diagrams that will help you.
  • Woody J Hiatt Jan 29, 2012
    I remember repairing one and I think the vent can be made to vent inside or out. If you have it up wire it up and see what happens to the air flow.right in front of you.
My GE model JVM1790SK Microwave randomly died yesterday. I had just finished cooking something, started it again, and while the timer started counting, the over did not start. Any idea what this cou
Had you noticed that it was getting weaker? Taking longer to heat a cup of water/coffee? If so then the magnatron was getting weak and gave up the ghost. They are expensive, probably cheaper to get another oven. the other likely failure component is the capacitor. Careful they contain power even when unplugged. Caps are not that $$. good luck
Jan 03, 2015 | GE JVM1790SK Convection/Microwave Oven
Dead ge microwave
magnetrons work only when the unit is cooking
it smells like an insulation from overheating wire so could be a fuse and failing transformer
take it in for a proper diagnosis and quote but if it is over 2 years old the cost to repair could be more than a replacement unit
May 26, 2017 | GE JVM1790SK Convection/Microwave Oven
Bought house with GE Profile Convection Oven. Do not know proper cooking directions, nor how to work many of the features. Also no light bulb in it & would like to know which one to buy. Need manual t
GE has the manuals for most of their appliances on their site: http://www.geappliances.com/service_and_support/literature/ . Just enter the model number and click Submit.
The direct link to the manual for the JVM1790 Over-the-Range Convection/Microwave oven is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40480-1.pdf . GE only lists the JVM1790CK, JVM1790BK, JVM1790WK and JVM1790SK.
I hope this helps.
Nov 10, 2011 | GE JVM1790 Convection / Microwave Oven
No power to microwave JVM1790SK ...checked outlet and it is live
HELLO.
Since the outlet is live,the power problem is from the microwave.
check on the back of the microvave to locate the fuse that control the supply of power to the microvave.
Change the fuse because it is unable to control power supply.
Then plug the microwave to the outlet.
Thanks .
Sep 19, 2011 | GE JVM1790SK Convection/Microwave Oven
GE model number jvm1790sk 01 over range microwave convection oven turns on when door is closed but i think it is the convection oven that is on cause the turn table does not turn and the light does not...
That's probably a shorted relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 16, 2011 | GE JVM1790 1000 Watts Convection /...
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
My convection microwave will not heat up in convection mode. the microwave function works just fine. is there a way to troubleshoot and repair the problem?
    usually if convection fails means there is problem in magnetron you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
please do rate me on the above said issue
Dec 30, 2009 | GE JVM1790SK Convection/Microwave Oven
I have a Ge jvm1790sk and while the microwave is running there is no internal light how do I replace it?
Unplug unit before entering.
The light bulb is behind the air vent at the center top of the microwave. Remove two screws at the very top front of the microwave and pull the vent cover forward at the top. Sliding left is sometimes necessary to release the bottom tabs of the vent cover. The light fixture will be behind this cover.
Good Luck. Reverse the above process to reassemble.
Sep 06, 2009 | GE JVM1790 1000 Watts Convection /...
My GE Profile Convection Microwave Oven - Convection not working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uijjf
Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
My GE JVM1790SK
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 You may have a bad door switch. We also have a file on door switches at our site.
Feb 15, 2007 | GE JVM1790SK Convection/Microwave Oven
Open Questions:
GE JVM1790SK Convection/Microwave Oven Logo
142 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
