Question about HP 1240 Plain Paper Inkjet Fax
Paper will not feed into the HP 1240 fax unless I push it slightly.
4 Suggested Answers
jimnfl
  • 17 Answers
SOURCE: outgoing fax does not feed automatically
I don't know any specific info related to the panasonic fax, but here is some "general" information that is usually universal. The fact that the paper feeds "with some help" indicates that everything is working... just not as well as it should. Very often, a problem like yours can be rectified by simply cleaning the original take-up/in rollers with some alchohol (I usually use 90%+ rubbing alchohol as it evaporates quickly and leaves little, if any, residue) on a rag. Also, there is usually some sort of "pressure pad/roller" (sometimes called a retard pad/roller") on these types of machines that work in conjunction with the primary original paper take-up roller. It can be either dirty or worn as well. This should also be cleaned. If it's a pad type system, often it just clicks/clips into place, and can be removed, the rubber pad itself flipped over in the retainer, re-installed, and the "un-worn" side then faces the paper offering better pressure for feed, and preventing multiple page feed. Hope this helps.
Posted on Jan 27, 2007
  • 186 Answers
SOURCE: Paper Feed Not Automatically Switching to Multi-Purpose Tray
Sounds like the paper out sensor for the cassette is either broken or jammed. Pull out the cassette tip the machine on its back and you should see a black arm hanging down. This should be able to swing back and fourth freely. Unless it is missing or broken.
Posted on Jun 26, 2007
SOURCE: hp fax 1020 will not feed paper in
About to junk my hp 1020. Has not fed paper for some time. Used to do it one at a time by hand, but now won't at all. Any suggestions?
Posted on Feb 01, 2011
HP LJ M3035 default paper source machine setting
setting and paper hand ling and set paper tray 3 .if not show check tray connector .
Feb 26, 2015 | HP LJ m3035XS MFP Laserpr Stapler Xtray...
I have a hpfax 1240 and I don't know how to connect it to my home computer.
As far as I can tell, the HP 1240 is a fax machine. It can make and receive phone calls, send and receive faxes, and make copies of paper documents. It does not connect to a computer. What do you see to make you believe it can connect to a computer?
Aug 02, 2013 | Office Equipment & Supplies
Im at my office right now and our fax machine is not working, we can send papers but we cant recive
Is it connected to a VOIP service?
if yes call you provider to help you tweak you r settings.
Mar 02, 2011 | HP 1240 Plain Paper Inkjet Fax
I get a paper jam report even though there is no paper in the machine.
Search for the fault in sensor. The first of them is on input section and ?nother the presenting, on output. Or sensor was fix or has been jam by sheet. May be it was broken off. Else, I must to know , what does the tipe of flash the led blinks, it is necessary and important. What does the colour of signals . And the flashing period?
Mar 14, 2010 | HP 1240 Plain Paper Inkjet Fax
I have HP all in one. The feed for fax stopped working. how do I fix it.?
try copying blank pages. If it feeds the paper, then try faxing again. If it does not feed the paper, then open the feeder and clean the rollers and the separator pad. You can use a coffee filter moisten with distilled or bottled water to clean them.
Try copying blank pages again to check if it feeds the paper.
Feb 18, 2009 | HP Office Equipment & Supplies
Fax double feeds sheets
This may occur if:
-the paper is too thick or too thin
-the roller mechanism is not properly aligned or has worn out
-the sheets of paper stick together
things you can try:
-unload the paper in the main tray and bend the stack of paper to loosen it up. Reload the paper to the main tray
Hope this helps!
Feb 17, 2009 | HP 1240 Plain Paper Inkjet Fax
Paper will not feed through the insert opening
Lift up the cover for the document feeder and clean the roller and pad with alcohol.
Nov 12, 2008 | Brother IntelliFAX 2800 Laser Fax
Changing user name on used machine
there is the HELP key on the pannel board press it and go in the user data so you can find your desire setting or go by function key
Sep 20, 2007 | HP 1240 Plain Paper Inkjet Fax
Jun 08, 2007 | Canon LaserClass 2050 Plain Paper Fax
HP 1240 Plain Paper Inkjet Fax Logo
56 people viewed this question
Seeker5211
Seeker5211
