Question about HP CP3525N Color LaserJet Printer
Colors are wrong. Cartridges say I have plenty of toner in each of the 4 ...but when i print the colors are not right. I did a color test and the yellow is barely visible. How accurate are the sensors that determine the quantity of toner ?..
    Genius:
  • 1,089 Answers
Each cartridge has a "memory tag" that keeps track of the cartridge use. It is highly unlikely that all 4 memory tags are bad. Are you using HP cartridges?
Have you calibrated the printer? Do a full calibration.
It is possible that the DC Controller is bad. Each of the "memory tags" reads and writes to the DC Controller. The DC Controller also determines which colors get printed. Have you changed the ITB (Intermediate Transfer Belt)?
Posted on Apr 01, 2011
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
Magicolor 2400W toner cartridges not empty
Have you tried taking the toner cartridge out of the printer and shaking it up a bit? Just make sure you do it outside or over a trash can. Shake it side to side.
Sometimes the toner bunches up and you can get some more life out of it by shaking it up.
Hope this helps
Thanks
Mar 24, 2008 | Minolta magicolor 2400W Laser Printer
My HP laserjet color 2600n printerhas just started this and now prints with a thin black line on right of page and the colours seem all wrong can I fix it, I have proper HP toners in which are 3/4's used. ...
First try the printer self test as described in the instructions. Then delete the printer driver and reload it. Give the toner cartridges a series of light taps as well. This is about the limit of what you can do.
Jan 16, 2011 | HP Color LaserJet 2600n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
Can someone please help me i have just printed off 400 prints with my brother hl 4040CN laser printerits brand new and its now saying my cyan toner has ran out this is impossible i am right in the middle...
Your toner usage will depend upon how much of each color toner is used on each page. (To conserve colors when printing in Black and White only, specify monochrome in your printer setup) <div>I had similar problems when printing publicity flyers. The toner cartridges claim to be good for about 2000 prints each, but I was lucky to get 3 or 400 pages when printing blocks of color. The TN115 cartridges hold significantly more toner, and the cartridges that come with the printer are TINY.</div>
Jul 06, 2010 | Brother HL-4040CN Laser Printer
Color alignment
Clean or repalce sensor belt responsible for the wrong color register.
Oct 22, 2009 | HP Color LaserJet 2600n Printer
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
Cant print in black when color toner is out.
Turn of the printer and remove each color toner cartridge and shake it good before putting it back in place, Turn it back on and then it should work. Also you might need to reset your toner cartridges. I found that information at UNI-KIT (toner refill people, reset the counter (Reset Gear)). I just refilled one and found out the hard way that there was a lot of toner left in the cartridge. Also I found that by turning the power on and off that will make it print for a while.
Mar 28, 2009 | Brother MFC-9840CDW Laser Printer
Two printers print only black
Swap all toner carts on both machines. Sounds like a toner cart problem
Jan 30, 2009 | HP LaserJet 2500 Printer
HP Color Laser Jet 3550 Smearing Colors
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Aug 11, 2007 | HP Color LaserJet 3500 Printer
HP CP3525N Color LaserJet Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
