Question about Casio G-shock G2300B-1V
Auto light wont turn off.
Every time i press light button to shut off auto mode, it doesnt work.
You need to press & hold the forward button on the right side of the watch for a few seconds. That will turn off the auto light
Posted on Jan 08, 2009
SOURCE:
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Does anyone have instructions for Nike Imara Fit WR0076?
    How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
    PLEASE READ CAREFULLY
    STEP 1:
    First hold the button for set/light.
    STEP 2:
    wait for the "hold to set" message to appear
    once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
    TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
    STEP 3:
    To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
    *If you are done setting the time press the set/light button, and there you have it.
    If you still need to change the minutes of your digital watch proceed to step four.
    STEP 4:
    After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
    To set MINUTE:
    press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
    *If you are done setting the minute, press the set/light button, and there you have it.
    If you still need to change the date specifically, the day of your watch proceed to step five.
    STEP 5:
    To set date, specifically, DAY:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
    To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
    *If you are done setting the day, press the set/light button, and there you have it.
    If you still need to change the date specifically, the month of your watch proceed to step six.
    STEP 6:
    To set date, specifically MONTH:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
    To set MONTH:
    press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
    *If you are done setting the month, press the set/light button, and there you have it.
    If you still need to change the date specifically, the year of your watch proceed to step seven.
    STEP 7:
    To set date, specifically YEAR:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
    To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
    *If you are done setting the year, press the set/light button, and there you have it.
    If you still need to change the 12/24 hour format of your watch proceed to step eight.
    STEP 8:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
    To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
    *If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
    If you still need to change the power hour of your watch proceed to step nine.
    STEP 9:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
    To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
    Press set/light to set POWER HOUR.
    May 13, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
    How do I set the time for nike imara fit WR0076-002 wrist watch?
    STEP 1:
    STEP 2:
    STEP 3:
    STEP 4:
    To set MINUTE:
    STEP 5:
    STEP 6:
    To set MONTH:
    STEP 7:
    STEP 8:
    STEP 9:
    Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
    Trying to set time on nike watch
    1. Press the bottom left button(MODE) to put on Time mode.
    2. Press the LIGHT button (ADJUST/LIGHT) for three seconds.
    3. Press the MODE button to select what you wanna change, be it hours, minutes, or seconds.
    4. The upper right button (START/LAP) is to move a number up, the bottom right button (STOP/RESET) is to move a number down.
    5. Press the LIGHT button to finish.
    Mar 13, 2009 | Nike Watches
    GapKids Digital Watch - Need to know how to set
    Light button is A
    Mode button is B
    Start button is C
    Reset button is D
    Standard Time Adjustment:
    1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
    2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
    3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
    4) Press D again until the next area you'd like to change is flashing.
    5) At completion of changes press Button B to resume standard time display mode.
    Nov 29, 2008 | Nike Triax Fly WK0006 009 Watch
    I dont know how to set the time
    STEP 1:
    STEP 2:
    STEP 3:
    STEP 4:
    To set MINUTE:
    STEP 5:
    STEP 6:
    To set MONTH:
    STEP 7:
    STEP 8:
    STEP 9:
    Nov 11, 2008 | Nike Imara Run WR0075-014 Wrist Watch
    Setting the date and time on watch
    time:
    hold left button -- hour will appear and begin flashing.
    press right button to set.
    press left button to advance to minutes, press right to set.
    date:
    press left -- date will appear. now hold left until day flashes.
    press right to set.
    press left to advance to month, right to set. then same again for year.
    Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
    LIGHT CASIO PROTREK PRG60 TRIPLE SENSOR
    Enter Altimeter Mode
    Press and hold Adjust Button
    Now press Baro Button
    (It will off Auto Light Function)
    Oct 25, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
    Setting watch
    Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish.
    To turn off alarm, press and HOLD Adjust button, then press Start/Stop to cycle through alarms on/off.
    Mar 25, 2008 | Timex 1440 Nylon watch
    Casio G-shock G2300B-1V Logo
    946 people viewed this question
    Top Casio Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ekse
    Are you a Casio Watch Expert? Answer questions, earn points and help others
