Question about Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B
Amana 25. cu ft..freezer not working...making rattling noise now and then
My side by side fridge and freezer is just a bit over 1yr. my freezer is making a ratling noise every "cycle"..thought it was making ice. now it freezer/fridge don't work. check motor..both inside and back end fans are running...but coil does not get "cold"...air from back end fan is cool...not warm. any suggestion will be great.
thanks in advance
  • Anonymous Mar 25, 2014
    vibration and rattling from gaggenau fridge freezer
    Problem Solver:
  • 12 Answers
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Posted on Aug 05, 2008
16 years old. cold inside, but not freezing food. making small rattling noise
check the RepairClinic site, as they indicate what may be wrong when there is a 'rattling' noise in a freezer
Jan 13, 2016 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
T-23f true freezer compressor makes rattling noise then starts sometimes i believe it is the over temp compressor relay
replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
Apr 06, 2013 | True T-23F 23 Cu. Ft. 1 Door Freezer
The middle part of the freezer and the fridge from my samsung is too hot.
hi there, sounds like you need to clean the back of your fridge, dust maybe blocking your vents, causing poor cooling on your condensor
Nov 16, 2012 | Samsung RS2530BBP 25 Cu. Ft. Side by Side...
How to disable deep freeze? plz give me solution.
If there are two compressors on your unit, disconnect the freezer compressor. If only one compressor, nothing can be done as the fridge and freezer piping are in series. Assuming you have an upright fridge.
Oct 23, 2009 | Amana 15.6 cu. ft. Upright Freezer...
Freezer LFFH21F7HW upright is making to much noise when it runs. Is this an ongoing problem?
Hi, What kind of noise is it making?
Also have you tried moving the fridge slightly incase its up against a unit or sitting uneven as this can cause a noise if after this you still have the noise their isnt much you can do about it as its not worth replacing parts that are working fine.
I would move the fridge slightly or adjust the legs so its sitting even as this can cause a vibrating noise.
Let me know how you get on or if you need further assistance ok
Aug 11, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
External Surfaces of Fridge/Freezer are hot
That is normal, refrigerators work by removing the heat from the storage area, thus making it cold. This heat has to go somewhere. Most of it is blown out the back but some escapes through the sides of the fridge.
Dec 28, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B Logo
334 people viewed this question
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Freezer Expert? Answer questions, earn points and help others
