Question about Akai LCT2721AD 27 in. LCD Television
I have to press the power button repeatedly. up to one hundred times for television to come on .
  • 68 Answers
You heave a problem with power sam electrolit capacitors
Posted on Mar 31, 2011
How do you program a Dish Network Remote to control a DirecTV receiver?
  • 1 Turn on the electronic device for which you'll be using your remote control. You will have to do this manually by pressing the "On/Off" button on the device.
  • 2 Locate either the "Code Search" or "Setup" button on your remote control. Which one you have will depend on the remote control.
  • 3 Hold that button for anywhere between five and 10 seconds. The light on your remote should then turn on. Depending on your remote, the light will either blink or remain on after you release the button.
  • 4 Press the corresponding button on your remote for your device that you are programming. In other words, if you want to program your remote to your television, you would press the "TV" button.
  • 5 Use the numbers on your remote to enter the three- or four-digit code for that particular device. The codes for your remote control will be found in the manual. Don't worry if you have lost the manual. You can find codes for practically every remote control on the market on the Internet. Visit the website of the manufacturer of the electronic device (TV, DVD player, among others) or log onto the "Universal Remote Control Codes" website. Once you have entered the code using the remote, you should notice that the light on your remote has turned off.
  • 6 Point your remote towards the device and attempt to turn the device off. If you can do so, you have programmed your remote correctly.
Programming Without Remote Control Codes
  • 1 Repeat Steps 1 through 4 found in Section 1.
  • 2 Begin pressing the "Up" channel button found on your remote. You will probably have to do this a few hundred times (or anywhere between five and 10 minutes). Once the channel changes, your remote will be programmed. Turn the device on and off using your remote to finish programming.
  • 3 Use the "Power" button if the channel button did not program your remote control. Again, you will probably have to press the "Power" button a few hundred times. Once the device that you are programming your remote to has turned off, you will know that you have programmed the remote control correctly.
Sep 14, 2011 | Televison & Video
After power cut need to reset vcr clock on philips vr750 but have lost the manual
Hi
To set the clock:
Manual Clock Setting
1Press the VCR button, then press the MENU button.
2 Press the PLAY [UP]or STOP [DOWN] button to select INITIAL
SET UP, then press the FF /OK button.
3Press the PLAY [UP] or STOP [DOWN] button to select CLOCK,
then press the FF
/OK button
4Press the PLAY [UP] or STOP {DOWN] button repeatedly to set
the TIME. Every time you press the PLAY [UP] or STOP [DOWN] button,
the time changes in one-minute increments. If you press and hold
the PLAY {UP] or STOP [DOWN]9 button, the time changes in 30-minute
increments
5Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
the DATE (month and day). Every time you press the PLAY
[UP] or STOP [DOWN] button, the day changes in one-day increments. If
you press and hold the PLAY [UP] or STOP [DOWN] button, the day
changes in 15-day increments.
When the month and day are correct, press the FF /OK
button
6Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
the YEAR. When the year is correct, press the FF /OK
button. The day of the week will appear automatically
7Press the FF /OK button once again to skip "AUTO
CLOCK" and go to "D.S.T." (Daylight Savings Time).
Press the PLAY [UP] or STOP [DOWN] button to set D.S.T. to ON
or OFF. If AUTO CLOCK is OFF, you may set D.S.T. to ON or
OFF only
8Press the EXIT/STATUS button
Jul 13, 2011 | Philips Televison & Video
I have a sanyo tv and the remote is no longer functional, i dug out my old urc11a universal controller and would like to know what codes i need to set the controller to my tv.
Try pressing the 'set code' or 'code' button and keep pressing it until the light indicator lights. Press tv and after that you are suppose to enter the 3 or 4 digit code and press enter. However, if you don't know the code, try to repeatedly press the power on button of the remote until you get a response from the tv set. sometimes it would take a hundred times or more before you can get a response. Once you get a response, press enter. I have tried it many times in universal remote controls and it works.
Oct 03, 2010 | Televison & Video
The TV was working great yesterday, but today, when you press the power button, th TV clicks on, then within 5 seconds clicks off, picture never appears but green light comes on until TV clicks off. ...
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Post comment here if I can assist you further.
SD TECH
Sep 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
Sep 24, 2010 | Mitsubishi WT-46809 46" Rear Projection...
I try to switch the TV on (either using Power button on the remote control unit on TV itself), but the TV switches itself off immediately. I tried it many times, quickly in succession, as well as after...
Let me know what you find and I will tell you what it means.
MAKE A COMMENT HERE and I will help.
SD TECH
Sep 18, 2010 | Mitsubishi WS-65807 65" Rear Projection...
How do i program remote for a sony dvd player
If you cannot locate the code for your device, try the code search method below:
Step 1: Turn on the device.
Step 2: Press and hold the "CODE SEARCH" button.
Step 3: Press and release the VCR, TV, Cable or Audio button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 4: Release the "CODE SEARCH" button.
Step 5: Press "ON/OFF" (or "POWER" for RCU500) repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button up to a hundred times (at a rate of once per second) if your code is towards the end of the preprogrammed list.
Step 6: When your device shuts off, press and release the "ENTER" button.
Step 7: With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test, and if it does not function correctly repeat steps 1 through 6.
Aug 05, 2010 | RCA RCU500 Remote Control
Venturer TV
I'm probably wrong, but try the code for LG
Jul 28, 2008 | Televison & Video
I have a Sole Control SC-545 and would like to know how to program so will work with my Zenith TV
CURTIS Universal Remote Control setup
  1. Turn ON your TV.
  2. Press FUNC button.
  3. Press TV button.
  4. Enter 2-digit code No. (either 01 or 05)
  5. Press TV button.
  6. Press POWER button to confirm.
Search Mode Method
  1. Turn ON your TV.
  3. Press TV button.
  4. Repeatedly press POWER button until TV go's OFF.
  5. Press TV button to confim.
Red LED will blink 3 times if wrong input is detected.
Jun 26, 2008 | Televison & Video
Red light on display not green as usual no power
Hold down the "input" button and "volume -" button while the MAIN POWER BUTTON IS OFF. Then turn on the main power button while those are held down, the light on the tv & avc box will turn green. When it turns green, immediately let off the 2 buttons and press "volume +" button, then press the "Main Power" button. Next step is to repeat the process about 20-40 times & the TV WILL WORK!. I have read that this may have something to do with the energy star compliant commands that can changed through the serial port.
The above is from psxpirate25. Thanks!
I had to repeat the whole process a couple of times to get rid of the factory setup firmware mode. Do it 40 times, I would mess up the sequence a couple of times. Keep trying, it does work.
May 30, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Akai LCT2721AD 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
