Question about GPS
I locked my keys want to make new one but dont waste my time or money pop-a-lock wants $300.00 plus the cost of reprogramming how do i know if i have security key and how can i get around this problem thanks J.P.
  • 32 Answers
If you meant to say "I LOST my keys" then no, there is no way around it. Call the dealer and see how much they charge, i found the best prices (and guarantee) from my dealer.
If you meant to say "I locked my keys IN THE CAR", then you should be able to get a local lock smith to open a door for $100 or less. I have AAA and they will pay for this, and also help find a local locksmith. If you are in a small town, the police may open it up for you.
Good Luck
Posted on Mar 31, 2011
Do I have to reprogram the security system after replacing the lock cyLinder with new keys
Don't waste your money on unnecessary sources and unwanted repairs. Get this manual online at www.reliable-store.com and get complete guide
on whether to repair or not, service it, and how to repair etc
Mar 13, 2018 | 2002 Hyundai Santa Fe
I replaced the ignition switch module on my 2003 honda civic and now the immobilization system will not let the car start it will crank but thats all I tried turning the key on to the full on position and...
the IMMO light tells you , IMMO is failing,
this is covered in the FSM 100%
rule one , never buy a car with IMMO, baring that, buy the FSM.
this is a complex system, and is unique to this honda.
the book covers this.
see here, for your free book,
http://hondatech.info/downloads/Auto/Manuals/Civic/
i run DIY immo on all my cars and bikes.
costs $1 (and no leash to honda)
honda's do have idle learn modes, up the ying/yang.
1100 pages
your answers are on page 22-165 (FSM)
rule 1, one fob, 1 key on chain or fail.
step 2, does key inserted and on,show key flashing
yes, remove pin 7p and go to step 9
see, it dont work like you think
no 2 cars have the same system. its 2003 honda. and is unique.
7p is in the IGN switch.
etc,etc
and step 14, oops a bad e-parking brake switch , see lamp for same.
Aug 31, 2013 | Honda Civic Cars & Trucks
I have bought a replacement tranmitter for 2001 Suzuki Ignis Remote Central Locking System. I have an original that works but cannot Program the new one as per Owner's Manual given to me when the car was...
TRY THIS IF DONT WORK DEALERSHIP HAS TO REPROGRAM TRANSMITTER.REMOVE KEY FROM THE IGNITION SWITCH.CLOSE ALL DOORS.SWITCH IGNITION ON.WITH IN 10 SECONDS, SWITCH IGNITION OFF AND REMOVE KEY.WITHIN 20 SECONDS, PRESS AND RELEASE DRIVERS DOOR COURTESY LIGHT SWITCH 3 TIMES, SWITCH IGNITION ON, WITHIN 10 SECONDS ,SWITCH IGNITION OFFAND REMOVE KEY.LOCKS WILL CYCLE TO CONFIRM PROGRAMMING MODE ACTIVATED. PRESS THE UNLOCK DOOR BUTTON TO CONFIRM THE DOORS OPERATE FROM LOCK TO UNLOCK. REPEAT PROCEDURE REMAINING REMOTE TRANSMITTER.IF THIS DONT WORK DEALERSHIP WILL HAVE TO REPROGRAM NEW REMOTE.
Apr 18, 2011 | 2001 Suzuki Swift
I 'v been this roblems over 3 years and spent so much money to fix it. My 1999 Oldsmobile Alero wont start with security theft light flashing. I have to wait for 10 minutes and then if i lucky it may...
SOUND LIKE THE THEFT SECURITY PROBLEMS. MOST OF THE TIME.THE IGNITION KEYS OR IGNITION SWITCH KEY LOCK CYLINDER WORN WHERE THE BCM AND PCM DONT RECOGNIZE KEY OR SWITCH SIGNAL.SO THE BCM AND PCM WILL GO IN THEFT SECURITY MODE.THE DEALERSHIP WILL HAVE TO FIX.BECAUSE IF THE KEYS , IGNITION SWITCH AND LOCK CYLINDER AND BCM HAS TO REPLACED.THEY WILL HAVE TO BE REPROGRAM USING DIAGNOSTIC EQUIPMENT. NOT A HOME FIX.YOU WILL NEED TO GET FIX SOON AS POSSIBLE.BECAUSE FAULTY SECURITY THEFT CODE WILL SHUT DOWN VECHICLE FUEL SYSTEM WHILE DRIVING OR IT WILL GET TO A POINT WHERE CAR WONT START NO MORE.THIS FIX WILL COST ABOUT $600.00.
Dec 23, 2010 | 1999 Oldsmobile Alero
Mercedes slk 230 1998 locks all doors with remote key then instantly unlocks please help
this sounds like a door switch not switching if you shut the door and left your kyes inside the car the door locks would pop up so you cant look yourself out,,,(but you can?) my money is on a door switch,, give them all a good swilling with WD40 to free them off if this dont fix it then its the car alarm it needs to be reprogramed to the kye fob and also fit a new battery to the kye fob at the same time people often forget how much work the kye fob needs to do and only when it stops working do they change the battery in it,
Feb 23, 2010 | 1998 Mercedes-Benz SLK
Does not lock with key or remote
hi friend,
I presume you've changed the batteries? If the batteries are good I don't know what to tell you dude, might need a new one
shake the key while holding it close to your ear, if you hear something moving inside the key then you need new key. there is a chip in those keys that if it comes loose you need then a new key. unfortunately it's not very cheap, key cost a little over $150. just order the key from the dealer, and if they tell you they need to reprogram the key in the car tell them you just want the key, because the key reprograms itself. all you have to do is put it in and let it sit there for less then 1 hour, and it reprograms itself. some dealers will tell you they need to reprogram it so they can charge you an extra $100, but in reality you don't need the re programing, just let the key in for less then 1 hour, then it is ready. hope this helps u please rate me................. thank u for using fixya regards sivaranjini
Nov 24, 2009 | 2002 Mercedes-Benz S-Class
The driver and passenger door locks only work by
The ford dealership is sure to have them, although other place like NAPA, or Autozone may be able to find you replacement ones for a cheaper price.
Aug 28, 2009 | 1997 Ford Explorer AWD
Just got my truck (2002 7.3) back from the dealer today replaced an ipr sensor and a cam sensor. When I got to my truck the the key fob wouldn't pop the locks on the doors (thought it must be a dead...
back up to the dealer ?if you didnt have these problems before then get it back and talk to the service manager dont start replacing things that can get expensive sounds like a body control module issue? let them reprogram it first ? if they dont make you happy call factory rep he can help ?
Aug 26, 2009 | 2002 Ford F250 Super Duty SuperCab
Theft system light is on
When the theft system light is on it should try to start, and almost immeadiately die. If it does this it is more than likely the cyclinder lock housing assembly, which reads the key code I have the same problem, it doesn't do it all the time, but when it does it takes about 11 minutes to recycle itself and then the car starts. I have checked everywhere and can't find a fuse to disable the security...The housing costs about $130 new, plus installation. One of the causes for wearing the housing out is to many keys on the key ring that adds pressure on the lock housing and wears it out. I suggest bitting the bullet and buying a new housing, then you have to have the computer in the car reprogramed to accept your key, otherwise you have to change the locks. Between that problem and the lowerer intake manifold leak (a common thing with the 3.1, 3.4, and the 3.8) I almost sold the car. cost me a total of $650.00 to have it fixed, which in some cases will be reimbersed by GM , for the lower intake gasket and repair.
Jul 16, 2009 | 1997 Chevrolet Malibu
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
