Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Refrigerator smells strange
My fridge smells really strange and there is no old food in it. When  I open the door to fridge and freezer it smells like a gassy plastic sort of smell. I am worried it is contaminating my food and the containers I have in the fridge smell strange now too. What should I do?
  • weimin_m Dec 09, 2008
    My tenant reported the same problem:
    "For a couple of days now, there has been a foul smell in our house. We
    checked everything and found that the smell was coming from the back of
    the refrigerator. We pulled the refrigerator out and cleaned under but next
    day same thing. We checked the inside, nothing rotting."
I may have found the problem. I pulled out the Fridge again. The odor was in the water pan.
What I found was that the cooling grills in the front was caked with dust. I vacumed this area but it was not until I got down with a flash light and saw this issue. I took a small duster that uses static to pull the dust out. There was a lot. I will see if the smell starts up again.
Posted on Jan 09, 2009
Bad smell from fridge (not mouldy food)?
There is no danger if there is a leak, but the refrigerator will quit cooling. I suspect perhaps you have a dead something underneath or behind the refrigerator. I hope this helps... but I also suspect you have cleared the problem by now.
Mar 25, 2014 | Freezers
Refrigerator Odor
Remove all the food from the unit and clean it with a diluted chlorine bleach solution and let dry and then do it one more time. Also get a box of baking soda and put it in the fridge to absorb odiferous smells odors
Jun 30, 2017 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My refrigerator and freezer smells like chemicals
Your problem might be something caught in the water hoses going into your fridge and condensation is freezing around it
Apr 03, 2012 | Whirlpool Refrigerators
The ice from the icemaker in my frigidaire has a chemical taste and smell. The refrigerator is old. I smell a bad smell when I open the freezer. What could be causing this problem? Model # for...
Some piece of rotten food stuck in the filter system.
Try replacing the air an water filters.
You can also make deep clean...
  1. Take all the things out of the fridge
  2. unplug it and clean everything inside
  3. Leave it like that with the doors opened for 3 days
  4. plug it back
Aug 24, 2011 | Refrigerators
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
Thick brown liquid at leg of of refrigerator
the thick brown liquid is decomposing moss, from the condensate inside the unit finding a way out.(think of it as the same stuff you get around a shower tray)clean out the fridge using clorine bleach and dry thoroughly....leave the door open for the clorine to gas off otherwise it will taint the food.when the smell has gone then close door and switch on.(some people use milton fluid,but clorine kills all known germs....)
Jul 16, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
I know this is strange but here goes. I have a Kenmore Coldspot side by side Refrigerator. This past summer, it was leaking water out the front freezer door. We turned off the water and called a repair...
Turn off the fridge. Remove the freezer bins in the bottom. Defrost the drain line with a hair dryer.It is on the lower back portion of the freezer. Break up the ice on the freezer floor and dispose of it.
Discard any old freezer food. Change out the water supply line with a copper line if you are using a plastic line.
Dec 23, 2009 | Kenmore Refrigerators
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
901 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
