Question about Philips MMS171 Computer Speakers
Hi, The right jack of my speakers suddenly got much quieter. There is still sound coming out, and I can use the speaker itself other places so it is not a speaker problem but perhaps a balance issue? I checked the balance on the device and it said they were both equal, but I was wondering if there was any other troubleshooting I could do.
  • Philips Master
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Mar 31, 2011
Ilive bluetooth 2.1 speaker system with subwoofer
try first to plug it into another device and see if the problem follows. If it is so .. then you are sure that is the speakers or connector .. and in my experience , almost no none gonna fix it .. because they have to charge more that buy a new one .
Dec 11, 2013 | Computers & Internet
Ilive bluetooth computer speaker system
replace the speaker with a new one :-)
but!!!
it can be aproblem with the amplifire !!!
if it bad in high levels and good in low its a speaker
if its bad all the way its a burn chanell in the AMP.
injoy
Dec 11, 2013 | Audio Players & Recorders
When I plug the speakers in, No sound comes out of them.
Hi, have you tried any speakers on your computer before if yes and these speakers you bought are not working even you turned the volume up they may be faulty, else it may be a cable problem, jack has not been connected at the right place or the sound driver is not installed on your computer. try to check if all is OK or even check the speaker by connecting it to an mp3 or any device using this type of jack if it is playing the problem may be on your computer.
hope that this will help and don't hesitate to contact me and don't forget to rate.
Best regards
Damien C
May 23, 2010 | Logitech V20 Computer Speakers
Line 6 spider 210 volume problem
The bypass switch in the headphone jack is likely broken. NEVER unplug the headphones while the amp is on.
There are certain small amps that have a possibilty of popping the power amp due to a feedback arrangement. Likewise, never use the headphone jack for ANYTHING other than headphones.
Dec 20, 2009 | Music
I have plugged in my speakers at right place but no sound is coming out of it. I also have a sound card of realtek nothing is helping. Please provide some solution.
Try changing the setting from the "Realtek HD Audio Manager" Select the correct input jack, double click it then "Which Device did you Plugin " window will pop up select the appropriate option and shall work. If this Does not work disconnect the speakers from the system, remove the sound drivers & reinstall it again, connect the speaker. This shall work now
Jun 25, 2009 | Ozaki DT-500 3-Piece Speaker System...
X-530 one speaker not working
this is a problem that i have faced as well it is likely that the cable going in to the jack could be loose and you might need to move it a bit, but in your case i think most likely would be that the input jack on the sub for the speaker is broken in that case you should call up logitech and ask technical support to see what they can do for you should be covered by warranty!
Feb 09, 2009 | Logitech X-530 5.1 Channel Speaker System...
Stereo Speaker troubleshooting
It sounds like the audio jack itself has internal damage. Depending on how it is mounted on your laptop case, or possibly on an internal circuit board inside the laptop; it might be possible to repair the jack or replace with a new 1/8" audio jack. Some soldering skill may be required after disassembling the laptop and getting access to the jack.
Jan 12, 2009 | Computers & Internet
Sudden crackles in the right surround speaker!
Your speaker is busted. You will need to get another one. It really can not be repaired and if it can, it will cost more than a new speaker.
Sep 12, 2008 | Logitech X-540 Computer Speakers
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
No sound through speakers, but ok through headset
u have a problem either on the speaker or on the sound amplifying circuit. signal coming from the earphone jack is not amplified. check the speaker first. if its ok then check the audio output ic(integrated circuit). good luck!
Jan 31, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Philips MMS171 Computer Speakers Logo
97 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
