Question about Canon MX700 Office All-In-One InkJet Printer
Please , someone tell me where does one replace the ink pacts in a Canon MX700. I've only used my printer a fews times, about a ago, I'm unable to find my manual and don't want to break the printer , thank you
  • 58 Answers
You lift the middle part under the screen and the top part should lift.
Here is the manual for download:
http://software.canon-europe.com/software/0032529.asp?model=
Posted on Mar 31, 2011
Canon printer
It shouldn't dry up in such short a time, not unless you've done a lot of printing and the cartridge has run out. The seller is taking the mickey.
If you've replaced with canon cartridges and it still fails, insist on replacement or repair under warranty.
If repaired, check that it works properly before accepting it.
Dec 20, 2011 | Canon Pixma MX420 All-In-One Printer
Have a mx700 canon that has error code 6000 is it just becuz im out of ink
no it not because your out of ink, it's a paper feed problem caused by some thing blocking the paper feed. look in all the hole see if you can find it if not it's a repair man time. that all i can tell you as im having the same prob and that what i've beeen told
Jul 05, 2010 | Canon MX700 Office All-In-One InkJet...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
How to refill pixma mx700 magenta ink tank without
The colors are individual. That machine takes the Canon CLI-8. I would suggest reading your manual on what the procedure is for changing the ink cartridges out, it typically varies slightly by machine. There should be an option somewhere one of the menus to change the ink cartridges. When you buy a replacement be sure you buy from someone who isn't trying to scam you. I would recommend Cartridge World, of course, or OEM. Do not use cheap online cartridges, you will only have headache later.
Feb 15, 2010 | Canon PIXMA MX700 All-In-One InkJet...
My canon pro9000 can't print, it said an ink tank error had been occured. meanwhile all the ink cartridge are new installed
1) Try checking your ink cartridge levels. This might tell you if theresa problem with your ink cartridge.
2) Make sure there is no paper jammed in the printer. If there is make sure you don't pull it out from the front. At the rear or the bottom of the printer is where you remove the paper.
3) Contact your printers manufactures website. Some have a live chat which means you can speak to someone online rather than email them.
Nov 07, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX700 printer ink lamp fast blinking
1) Insert both ink cartridges and then check the ink levels that way it will tell you if there is something wrong with them.
2) Make sure you buy 1 colour ink and the other black and insert them into the correct slots.
3) Contact your printers manufacturer by going on there website. They may have a live chat.
4) Try this link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651
Nov 03, 2009 | Canon MX700 Office All-In-One InkJet...
My Printer is saying, some ink tanks are not
If the cartridges are in the correct position, you may have defective cartridges. If you are using after market cartridges, the electronic sensor chip built into the cartridge may be defective. I would remove the cartridges and try using OEM cartridges. You can also try new aftermarket cartridges from a different vendor. This should clear the problem.
Let me know if this does not solve the problem and we can look into other potential solutions.
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer spits out black ink and smudges when printed
Your printer apparently needs to be cleaned, using your canon software utility. If the cleaning doesn't help, try to replace cartridges
May 31, 2009 | Canon MX700 Office All-In-One InkJet...
Will PGI-5BK and BCI-3E ink tanks fit in the MX700?
Ink Tanks:
PGI-5BK, CLI-8C/CLI-8M/CLI-8Y
According to the canon australia website these are the inks for the MX700
Feb 20, 2008 | Canon MX700 Office All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
47 people viewed this question
old marine
old marine
