How to set picture size on vizio flat screen with HD
  • 28 Answers
You can go to settings and then by adjusting screen resolution you can set the size of picture
Posted on Mar 31, 2011
Picture doesn't fit the screen
Its a function of the source and the tv picture settings. Go to the source (direct tv, cable, co-ax?) menu , settings and look for screen display sizes.
Your remote has a red dot "wide" button which will also have a screen size effect. You can cycle through the formats
For further info why not read/print out the manual?
http://store.vizio.com/documents/downloads/hdtv/L32/Manual.pdf
Mar 19, 2014 | Vizio L32 32 in. LCD HDTV
Vizio 32" HD flat scene tv no picture no sound will not turn off
if no picture no sound how can it turn off--you mean a light is still on? Let me also know age of set and if any odd things before it failed like had to turn on several times etc.
Apr 23, 2012 | Vizio L32 32 in. LCD HDTV
Cannot get picture to fill screen
Press menu on your remote control. At the top you will see selections. Scan through the selections until you see the set up menu. Go to the wide setting and it will give you different screen size options.
Jan 01, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
Cannot adjust picture size on vizio
If the picture size isn't changing with the television's picture size adjustment setting there could be a few things going on. Check to see that you're in the right input on the television i.e. if you are connected to a high definition receiver make sure you are not in the tv/tuner input (tv display would say analog channel 3 or 4). Make sure your tv is switched to the high definition input i.e. component 1 hdmi 1 and etc. If you are in the high definition input already check and see that your cable box or satellite tv receiver is set to the proper resolution. For example if you have a 720p television make sure the cable box is set to 720p not 1080i. Last but not least look for the hd zoom # button on the cable remote. The button may also say format or aspect.
Aug 19, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
The image on my VIZIO 37' isn't covering the entire screen. Some of the HD channels cover the screen, but some don't and non of the non-HD channels cover the screen. I've go the the Wide Screen setting...
It is unfortunate that there isn't just one standard size or format, by which all programming is sent.
Programming format (size) varies from program to program.
Jun 13, 2010 | Televison & Video
Picture not filling screen on vizio 37" tv
Hi my name is Eric,
I hope I can help you with your issue ,
There are a few buttons to adjust the picture size on different make TVs and even on the Cable/Satellite remotes .
1.Format
2.Aspect
3.Size
4.Zoom
5.Wide
6.#
First look on the TV remote, set it to Full ,Fill or Just.
Then on the Box remote stretch is usually best.
On the box remote set the output resolution to 1080i only
And use 16x9 when if offers a choice.
Cable remotes use the # key as a zoom button.
Due to the fact there are 16 size/Formats available (3 or 4 being transmitted now). you may have to hit the zoom/stretch button on some HD channels.
But with these settings the picture will mostly stay full and help you avoid image burn from the edges being not on the edge.
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Vizio L37 Television
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
Does your tv have a setting for picture size? Check that.
Sep 01, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
594 people viewed this question
Top Televison & Video Experts
Electro Med Services...
