I have a Toshiba CF3566A television that was working fine until recently. I went to turn it on using the on/off button and nothing would happen. It would not turn on using the remote either. I did notice that after trying to turn it on, the TV made a light ticking sound like a clock. I unplugged the TV and the ticking stopped. When I plugged it back in, it would still not turn on. Do you have any advice on this?
    Problem Solver:
  • 11 Answers
You may have a problem in your power supply.
Posted on Aug 05, 2008
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
TV just went black. Power indicator is flashing but nothing is happening. Anyone know what just happened?
Sounds like a common problem with this Toshiba 50inch. Here's another discussion: Might be worth the full power OFF/ disconnect trick, to reset things. Power supply is shutting down, maybe due to overload. Plasma screen often uses parallel driving MOSFET transistors. If one fails - it stops them all working, until it is replaced.
May 12, 2012 | Televison & Video
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Dec 14, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Will not power up ?
this is a very common problem among these projection tvs and the best thing to do is toss the damned ting out. i myself had a panasonic tv and it never turned bac on. i waited over 2 months and neer turned on. the lamp in the back has blown and its very costly to fix due to they dont make these tv no more.
Jan 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
TOSHIBA 57 H 81 wont play 480p any more Green Screen
this happened to me once and what i found was that i had missed a defective component.. these parts need to be checked for ESR also check the solder connections....john
Aug 24, 2007 | Toshiba 57H81 57" Rear Projection...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
