Question about Car Audio & Video
How do i wire a 500k micro farad compacitor ot my exsiting amp? need a wire diagram or detailed instructions thanks
  • 635 Answers
The capacitor has two terminals. One is + and one is - . Your Amplifier has three terminals on the power connector. One is connected by a Black wire connected to the body or - of the battery, the second is a Blue wire connected to the remote wire of the Head unit ( for remote ON/OFF of the Power Amp ). The third is the Red wire connected to the + terminal of battery through a big Fuse .
Connect the Capacitor + to the terminal with the Red wire and Connect the Capacitor - to the terminal with the Black wire. Make sure you use heavy cables to do the connection and try to keep the length of the interconnecting cables as short as possible ( to minimize losses ). In other words try to connect the Capacitor as close as possible to the Power Amplifier for maximum efficiencyhow do i wire a - bobhifi_26.jpg.moz-screenshot-1.png
Posted on Mar 31, 2011
HOOKING UP THESCOSCHE 500K MICRO FARAD CAPACITOR. I LOST THE HOOK UP DIAGRAM AND DON'T WANT TO HOOK IT UP WRONG
Connect ground wire to ground. Connect positive wire to the same positive wire as the amp is. If you lost the charging resistor then connect the wire to the cap first then connect to the power source. This will keep it from sparking and damaging the plating on the connector.
Jul 31, 2016 | Heating & Cooling
Duotherm a/c 59516.331 p/n 70130997 need to know what is attached to the top of compacitor...need to know the mfd for run compacitor as well as start compacitor. think run compacitor is=35.5 @ 370..
The wires attached to any component is shown on the wiring diagram. Use the same values that's printed on the capacitors, when replacing them. Call the manufacturer for any missing technical information.
Aug 27, 2013 | Heating & Cooling
59516.331 need run and start compacitor mdf.
Remove the ones that you have and match the voltage and micro farad rating printed on them.
Aug 27, 2013 | Dometic Rooftop RV Air Conditioner
How do you hook up scosche 500k micro farad digital stiffening capacitor? Read more: http://wiki.answers.com/Q/How_do_you_hook_up_scosche_500k_micro_farad_digital_stiffening_capacitor
you hook it up like a battery. positive to positive supply, and negative to negative supply, or ground. it may require a remote turn-on from a head unit, if there is a digital display on it. usually, it is the tiny screw, that looks like it holds the plastic cover on.
Aug 31, 2012 | Car Audio & Video
I NEED YO KNOW HOW TO HOOK UP A MICRA FARAD 500K
When I used to do this, I would run the power wire from the battery to the Capacitor and then run power wires to said amp. For the crossover, just run an 16 or 18ga wire to one of the Amps power input instead of running it to the cap if its easier. Not sure what Crossover you have, So check the manual for the correct wire size!
Nov 21, 2011 | Audio Players & Recorders
Need wiring diagram for tsunami 1.2 farad capacitor cap.
After a bit of searching I found the instruction manual:
http://a248.e.akamai.net/pix.crutchfield.com/manuals/120/120pp912u.pdf
Hope it helps.
Mar 05, 2011 | Metra Tsunami 1.2 Farad Capacitor
Describe how to connect a scosche 500k micro farad
Put the capactior in parallel with your battery right before the amplifier. So Postive lead of cap to your 12 Volt line and negative lead goes to ground. It is also suggested that you charge the cap before placing it directly in parallel with the 12 volt rail. yo ucan do this by using a 1000 ohm resistor with a power rating of 1 watt. Disconnect your amplifiers so it is just your cap and battery. Replace the fuse with the 1000 ohm resistor. Once the resistor is in place hook up your cap. It will take a little bit for it to charge. RC time constant is T = Reistance X Capacitance. So 1000 ohms X .5 Farads = is about 8 minutes, or you can just measure the voltage with an volt meter and when the cap reads 12VDC you can then hook it up. BE CAREFUL NOT TO SHORT TERMINALS. THIS CAPACITOR I STORING A LOT OF CHARGE.
Jan 26, 2010 | Car Audio & Video
Looking for a diagram so i can see how to install the installing scosche 500k micro farad and do i have to sauder it.
ok this is an easy one first make sure u have all your wires ran through the car connect a ground to the negative side of the cap then run 12 v power wire and use another piece of power to connect to your amp
Sep 29, 2009 | Rockford Fosgate Car Audio & Video
I trickle charged a new scosche 500k micro farad capacitor and when i hooked it to my trucks system it threw my amps into protection. so i replced both subs and got rid of cap.now the cd reciever plays but...
do the rca's work and does the speakers work on the radio. if the rca's don't work the rca's do have a fuse inside right next to the rca's on the circuit board. it is a small black rectangle soldered on both sides and has the letter f on it. if no sound comes from the speakers on the doors the output on the radio is probably damaged. the item number of the part is tda 7856
Sep 08, 2009 | Sony Car Audio & Video
I installed a scosche 500k micro farad capacitor in my truck. i have a 800w sony explode running a volvonhag 12" sub, the doors are run by a rockford 40i amp. sounds great till capacitor hook up. amp cuts...
You need to put the capacitor after the in line fuse/ distributor block. Because you are putting it on only your subs you are running it into fail because of a negatuve ground loop which is why they play low then cut out. Also check your grounds for both amps after rewiring and make sure they are tight.
Sep 07, 2009 | Car Audio & Video
Car Audio & Video Logo
444 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
