Question about Xantrex Technology Statpower Prosine 3.0 805 3030
We have blown 2 xantrex 3.0 and dont know why. there r 2 in the coach but only #1 keeps poping. it only controlls microwave and refridgerator. we do have a surge guard plu /ats and it still only pops that one. any sugg? thanks,jason
Looks like I have found the problem with why my two inverters smoked. I did not have shore power and was using a Generator. I purchased a New Generac 7kw gen. Well there is a short between the Neutral and the Ground on the Gen. Not sure if this intended or a defect. So When I connected it and the Inv sensed shore power the charger would come on and in about 15 min it would just burn up. Never tripped the breaker. This is a design short fall in the inverter and it should have a protection circuit to warn you and shut it down, I am using this in my camp and it almost burned down my camp! I have switch to a different brand inverter now.
Posted on Jan 22, 2012
I need a Control Board for my TR2424.
why do you need control aboard where are you fitting it and to what i have one on my coach its wired straight from my batteries
Nov 18, 2014 | Xantrex Trace Series TR2424-120-60...
Replace fuse
follow the next steps and fix it. use the VOM . God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).f8629014-97b9-47e3-91bd-92cf0f66526b.gif
Jun 16, 2013 | Samsung SMH7178STD Microwave Oven
We have a high pointe em925rsl in our brand new camper. The microwave keeps cutting out at the breaker. It has a 15amp on the breaker and it feels warm to the touch. Nothing else goes off when microwave...
test the following steps using the VOM and fix it. God bless you
5. Clock needs to be set before other functions will operate (some models).1bd565e9-a93b-42eb-b6be-1d95a42e71c1.gif
Jun 16, 2013 | Microwave Ovens
MICROWAVE PROPLEM
follow this next steps, use the VOM, and fix it. God bless you
5. Clock needs to be set before other functions will operate (some modelsbcd93e93-ccee-45ab-ba5c-70967b1ff19b.gif
Jun 11, 2013 | Sharp R-1874 Convection/Microwave Oven
My Prosine 2.0 display panel displays Panel Fault: Memory error and the display error as well as all lleds are off. The unit looks as if it has no power to it. I reset (power off.power on) the prosine and...
This is a know and widespread problem with the Prosine 2.0, yet when you call Xantrex, they want to charge you to return, repair and/or replace the remote panel. Shame on you Xantrex.
Sep 06, 2010 | Xantrex Technology 806-1800 Prosine...
The inverter dose not charge the batters on my coach.
From the manual I read on the Xantrex website shows 2 fuses. 1 in the F1 Position which is the outer circuit breaker, and the other in the F2 position. You can see the F1 tube-style fuse from the front, but the F2 fuse you have to tuck your head behind and see it from the other side. You can see if the fuse wire is burnt. To be sure, use an ohm meter to check the continuity of the circuit. Hope that helps.
Jul 27, 2010 | Xantrex Technology Xantrex 458 10 12...
Start button doesn't work for all microwave functions--as well as timer--fuse is ok
Possible causes:
Dec 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Why did my maytag microwave oven power go out completely?
1 your inline fuse blew
2your magnetron t-stat poped
3 bad voltage from outlet
test the outlet with a lamp, if that works it can only be the other two
open the door, take the screww off the control panel
and the vent cover, two screws on top
behind the control and vent you will see the mag t-stat, it should read continuity, and the inline fuse should be right above it a small glass tube fuse like a car
Oct 16, 2009 | Whirlpool MH3184XP Microwave Oven
My Xantrex rs400 stop working
First and foremost, It's a piece of ****!
I've been fighting with Xantrex for 3 years now and after 3 replacements I'm still stuck with the same erratic behavior. I don't trust it and Xantrex is not even responding anymore.
This is my review at Amazon
http://www.amazon.com/XS400-400w-Sine-Wave-Inverter/dp/B000A7MW5E/ref=sr_1_1?ie=UTF8&s=sporting-goods&qid=1256963563&sr=8-1
I know this is not helping you much but I thought it would be nice to know that you are not alone!
Richard
Aug 05, 2009 | Xantrex Technology RS400 Sine Wave...
Xantrex Technology Statpower Prosine 3.0 805 3030 Logo
138 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
