Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
ICE BUILD UP IN THE FREEZER
HOW DO I FIND THE HOSE AND DRAIN PLUG FOR THE FREEZER?
  • anne reagan Feb 20, 2009
    I have the same problem. But I can't find the defrost timer on my bottom-drawer Maytag. Where is it?
    I can't find the defrost timer on my bottom-drawer Maytag (need to adjust it because food side warm, freezer side cold and icy). Does anyone know where it is located? No manual addresses this.
    Problem Solver:
  • 6 Answers
If you are having ice build up in the freezer, the problem is likely to be the defrost timer. That timer turns on heating elements and melts the ice and the melt runs downd into a tray under the bottom of the cabinette where heat from the condensor evaporates it into the air. Look and see if there is any information in your manual or online Maytag books or service information as to where the timer is located. Most can be turned by hand and that may let you change it to defrost mode until the ice is gone and prove that it is the timer that is bad.
Good luck,
Glenn
Posted on Nov 09, 2008
Ice build up in bottom of freezer can not trays
Hi Bill:
Could be that the drain for the auto defrost is plugged.
The hose on the back goes to an evap tray under the fridge, and the top is connected to a funnel at the inside back under the freezer compartment.
Grunge and nasty things can plug the components. Clean and blow out and it should work.
Cheers
Feb 23, 2016 | Refrigerators
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Ice continually forming on bottom of upright freezer
you nead to clear the drain.when you clear the ice you nead to make sure that the drain is clear.a spider can build a nest in your drain line.if you remove the ice,you nead to clear the drain line with a hose.you nead to blow though hose and clear line.
Nov 18, 2009 | Ovens
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Whirlpool Side by Side Freezer - Ice Build Up in Drain
After the drain thaws , ( I use about a 4 inch aluminum fence tie or if need longer , aluminum wire with no insulation ,) insert it into the drain hole as far as it will go with no force , and wrap the top end about 1 turn around the calrod defrost heater , This transfers heat to the hole so the ice will not freeze up the hole . Before doing this step , use a hose and blow into the drain to possible clear out any debris which could have accumulated in the drain trap .
Jul 21, 2009 | Whirlpool GC5THEXNS Stainless Steel Side...
Defrost hose plugs
Remove the back cover to access the top of that drain line. Take some table salt in a tablespoon and dump in the tube. Will drain so fast you won't believe it. Might have a big build up of ice blocking the top so get your hair dryer and defrost that big build up. Flush with small amount of water and monitor the drain pan located under neath the freezer. hope this was helpfull
Nov 26, 2008 | Arctic Air 22 cu. ft. Commercial Freezer...
Frigidaire side by side freezer- water which turns to ice is collecting at the bottom of the freezer - drain hole at the back / lower part of the freezer appears to get frozen - causing the water / ice...
this should not be happening as a heater in the freezer should eliminate this problem.first check the hose is completely clear,if it is when your fridge goes into defrost mode you should be able to feel warmth near this drain or hear the ice crackling and defrosting thence draining via the rear tube also try removing the offending ice in the drain with hot water
Aug 11, 2008 | Frigidaire Refrigerators
Refrigerator
I just fixed similar issue. Defrost drain plugged. Take back panel off and behind fan is back hose. Take it out from the bottom and use something like coat hanger to unplug.
Also need to take off front panel from inside freezer and remove ice build up and thaw with hot water or hair dryer. Once done you should notice water in drain pan from back. Put all together.
Feb 01, 2008 | Frigidaire FRS3R5EMB Side by Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
85 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
