Question about Sony SA-WM40 Subwoofer
My Sony SA-WM40 subwoofer has power, but sound kicks out. I'll turn off power for about 5min and when turn power on, sound is back. Is something overheating?
    Brigadier General:
  • 8,546 Answers
Probably, or the woofer coil itself is experiencing a heat, volume or motion related short. Clean any dust or debris from the heat sink fins in the back. Make sure it has lots of space for cooling ventilation.
Posted on Mar 31, 2011
Sony sa-wm500 subwoofer is crackling
If the sound is a scratchy type of sound then the voice coil has been damaged and is rubbing up against the internal magnet producing the scratching and low sound since the cone is barely moving;.
May 19, 2015 | Sony SA-WM500 Subwoofer
My sa-ma40kicks off after it plays for a few minutes
This sounds like a power supply problem. If it works after is sits or cools, check at the power supply for bad or disturbed solder connections, a lot of time if you look at the circuit board where the component comes through you will see a small ring in the middle of the solder.
Dec 22, 2010 | Sony SA-WM40 Subwoofer
Sony SW no sound
does this sub have an LFE output? if so, connect that to the LFE input on the reciever and make sure it is set up properly in the set up menu in speaker configuration. if the sub has speaker line input outputs, connect speakers to input of sub and out of sub to amp/recvr
May 10, 2010 | Sony SA-WM40 Subwoofer
The speaker will cut-out after it has been playing a while. It will click-off, like it is going into a power-save mode, then back on for a few seconds or minutes...then back off again.
Sounds like you have an heat sensitive semi-conductor that might be connected to a relay (the clicking thing). As it warms up it acts up!
You can pin it down by spraying suspected parts (while under power and when it acts up) with Servisol Freezer Spray. Only spray one part at a time. The faulty part will return to normal, till it warms up again, or you force it to by touching it with a soldering iron.
If nothing happens to the part you spray, it's working and test the next. Don't bother to spray non semiconductor parts.
Apr 12, 2010 | Sony SA-WM40 Subwoofer
The speaker is starting to buzz during the low
It probably buzzes all the time, you just notice it when it is outputting little volume. Check the cables for loose connections or replace them with other cable as a test.
Mar 08, 2010 | Sony SA-WM40 Subwoofer
No sound from Sony SA2500 subwoofer
Please intimate exact model number written on sticker pasted at back of Sony subwoofer to provide you help.
Aug 01, 2009 | Sony SA-WX700 Subwoofer
Sa-wx700 with no sound
If you are a rock music lover, chances are the speaker has burn out. try to turn on and place your ear near the speaker and listen for humming
sound. if no sound at all, then its the speaker
Jun 26, 2009 | Sony SA-WX700 Subwoofer
I don't have no power replaced the fuse still no power
i have a sony subwoofer with no power. i found out that the voltage regulator (ic's)are bad. check that.
Dec 07, 2008 | Sony SA-WM40 Subwoofer
Regarding Sony SA-WM250 Subwoofer
There is probably a bad solder joint or loose wire inside of the sub box. If you can, unplug the sub, take the screws out and remove the back to inspect the circuit board. A clean solder joint is pointed and shiny, with the solder evenly distributed in the hole. Also check to see if any plugs are loose. Plug in the audio input and then the power, but be very carefull not to touch anything inside the box while the cord is plugged in!! Play some bass at moderate volume so there is pretty constant sound. Now, take a screwdriver with an insulated handle and gently tap around on the connectors and circuit board. Tap a little harder if nothing happens, also tap in different areas to try to force the sound to cut out. You can try to locate where the bad connection may be by tapping lightly and zeroing in on the location. When and if you find the problem, you will need to solder the connection with a soldering iron. If you don't have a friend to help, try a local electronics store. Good luck!
Jul 12, 2007 | Sony SA-WM250 Subwoofer
Sony SA-WM40 Subwoofer Logo
566 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
