Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
Slow to cool changed the defrost board since it the coils was freezing up. the fan works, but the air to the fridge side seems slow. I have to turn the thermostat to 5 which is 1 higher to reach 0 dergrees in freezer and 40 degrees in fridge. The unit is about 2 years old
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
My Amana refridgerator does not cool but the freezer works
If you have noticed a rise in temperature in the fridge, and there seems to be fromst building up in the freezer than your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Sep 07, 2012 | Amana Refrigerators
MTB1895AE Maytag fridge isn't cooling, freezer seems to be okay except for frost build up
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Jun 22, 2012 | Maytag MTB2156GES Top Freezer Refrigerator
The top half of the evaporator is freezing and both sides are not cooling enough
Jun 07, 2012 | Jenn-Air JCD2292KTW (21.6 cu. ft.) Side by...
My fridge freezer freezes up inside
May 29, 2012 | GE Refrigerators
Hotpoint fridge not working
May 27, 2012 | Hotpoint FFS90 Bottom Freezer Refrigerator
Both sides of the refriderator is not freezing or cooling
hello,
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly. Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly. * Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches). * Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section. * Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working. * Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover. Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer. Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils,
I hope this work fine...Take care.....
Oct 31, 2010 | LG LRSC-26922 Side by Side Refrigerator
The freezer seems fine but the other side is not very cool.
I had the same problem w/mine, Found out it was the timer. There is a timer on most fridge's that turn on a defrost lamp inside your fridge. That is why all fridgs are frostless now. They still freeze up, but a lamp will defrost them automaticly. When the coils freeze up, they wont cool the fridge side & but will still cool the freezer side. generally the timer is where the controls are, behind the cover.
Mar 31, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
81 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
