Canon imageRUNNER 400S Copier Logo
Anonymous Posted on Mar 31, 2011
My xerox machine IR 400 gets an error e677 - Canon imageRUNNER 400S Copier
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
93
Points
Http://www.fixya.com/postanswer.aspx?thid=8792841&prdid=189719&ctgid=169&ref=unslt
I am having IR 400 Xerox *** Printer. it is showing the error as Switch Main Power off & On E677. The Xerox is working fine, but only printer is not working...... Kindly suggest what to...
This is a communication fault between the printer board and the copier. The problem could be any one or more of the following - PDL I/F board, system motherboard, or image processor. I would try resetting all the circuit boards of the interface box. This is located at the rear in the upper right. This is where the fax board could be located as well. You may have to have a qualified tech do this work. Good Luck.
13helpful
3answers
Ihave problem with canon ir 600 .Error show E677
E677 communication error between machine & pc.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
1helpful
3answers
Eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
28helpful
4answers
E677 Error in canon IR400
switch main power off and on E677
5helpful
2answers
CANON IR 400 COPIER - ERROR - E677
old marine
old marine
ZJ Limited
ZJ Limited
