Question about Kenmore 56539 / 56532 / 5653 / 656534 Side by Side Refrigerator
No ice production, water dispensing solanoid valve would not shut off once engaged. replaced unit and problem fixed. stopped making ice about 2 weeks later. tested ice maker soanoid valve(on new unit) works fine.IR beam not blocked, resevoir is empty, no blockage of beam.accel ice on, switch on in freezer. Noticed that the valve could be heard opening up for just a second[not enough to fill tray] now no noise at all. Seems there is no signal being sent to valve . IR beam thingy? Ice maker it self ? Help please.
SOURCE: ice maker not making ice
Check the cam wheel beneath the front cover of the icemaker it is probably not turning.
Posted on Aug 31, 2007
fridgetech
  • 473 Answers
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Posted on Oct 18, 2007
fridgetech
  • 473 Answers
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
Posted on Oct 20, 2007
  • 262 Answers
SOURCE: Ice maker not making ice
you need a module cant remember the part number off the top of my head but go to repair clinic .com or your local appliance parts dealer with model and serial # in hand it may be quicker for you to get a new ice maker and easier
Posted on Dec 04, 2007
docjohn174
  • 943 Answers
SOURCE: Kenmore Ice Maker Problem, Side by Side Refrigerator
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Posted on Sep 11, 2008
Ice Maker fails on occasions to dump ice before water is dispensed
monitor the cycle as it is filling water does it over fill or is there a seepage that continue to drip, it could be the water valve. Also do you hear the tray making noise as it tries to dump the ice "the harvest cycle" try to watch it to see if it is a mechanical gearing problem
Nov 19, 2013 | Refrigerators
Ice maker stopped working, but used to work very well. During a course of a week, ice production kept slowing down to nothing. Test button on the side of the ice make unit does nothing. Unit is only a...
I had a similar problem with my Samsung fridge, my problem was the the ice holding unit had been taken out and not reinstalled correctly,
There is a rod on the rear of the tub and it has to be placed properly in the drive gear at the rear of the ice making housing so that it fits properly and smoothly.
If you still have a good water supply available at the door then the problem is probably what I just described, Good luck
Aug 27, 2011 | Samsung RF26VAB (25.5 cu. ft.)...
I have a frigidaire side by side with ice maker and water dispenser. when it goes to make ice, water drips out of the water dispenser. once the ice maker fills up it shuts off. it drips enough to fill a 16...
Mine would seep water out of the dispenser after I poured a glass of water and or the ice maker would use water. Not much, a few drops at first but it kept getting worse. I found out that there was a lime build-up in the dual solenoid water valve. To get to this valve, gain access to the back bottom of your fridge. Shut the water supply and pull the power cord. Remove the cardboard cover, disconnect all tubes connected to the valve unit and pull the electric plugs. Remove the 2 metal screws holding the valve assembly and pull it straight out (the other end of the valve assy is held by a key hole type slot). Now that you have the valves out, blow in the supply inlet and you should see if one of these valve is not making a perfect seal. Once you have this figured out, it is time to fix it. The valve are a sealed unit and opening them would wreck them but you don't need to take them apart. A replacement valve assy will set you back a $100 but there should be no need for a new valve. Not much in there can break. Just pour a little CLR or Lime out in the inlet and use a small tooth pick to push and release the valve plunger in and out. Put as much liquid as you can fit in and let it stand for a few hours until the calcium has dissolved. Work the plunger again to free the big stuff, rinse it all and blow to confirm that the seal is now perfect. Put it back together (easy, all the lines are colour coded. Make sure you don't have a leak and push your fridge back in its spot. Voila! P.S While you are in there, you may want to vacuum the condenser and all the dust you will see. You should have no shortage of dust... smile.gif
Cheers
Jun 26, 2011 | Refrigerators
Ice maker is not working and soft ice is forming around the area where the opening of the ice dispenser
Most of the time where they are making ice at the fill tube point the icemaker water valve in the back of the unit is leaking / dripping water past the valve / diaphram seat and it will have to be replaced. You can prove this by turning off the icemaker and then pulling the tube off the back of the unit and placing it into a bucket over night. If your sure the icemaker is off and there is water in the bucket the next morning the water valve is bad.
Now as for that ice in the icemaker fill tube... you can use a hand held hair dryer to defrost it once you change the water valve. I just changed my own water valve on a maytag less than 2 weeks ago that was doing the same thing. (Ice in fill hole and tube) It is working like a champ now.
A GE replacement dual outlet water valve:
http://www.appliancepartspros.com/Appliance-Parts/GE-Dual-water-inlet-valve-kit-item-number-AP3672839.aspx
(Make sure to use your model number when seeking the correct replacement see "useable on model list" bottom of the page)
Thanks for choosing FixYa.
Kelly
Aug 29, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice/water dispenser not lit or working
I think this is probably just a coincidence that you changed the water filter and a couple of weeks later the dispenser doesnt work. If it failed the same or next day then possibly related but unlikely. The water filter purely affects the water supply line. Does the dispenser (water) make a noise (clicking) when activated. If it does then I would check the incoming water supply. If it makes no noise then you possibly have an electrical fault not providing power down to the water solenoid valve. The way to check the ice dispenser is to see if you first have any ice production if you do then again it could be an electrical control fault. You could check the underneath of the cabinet low level for the wiring connection from the door to see if it is dislodged or damaged however if it is a control issue then I would suggest contacting a good fridge tech. Hope this helps.
Sep 05, 2007 | Amana ACD2232HR Side by Side Refrigerator
Kenmore 56539 / 56532 / 5653 / 656534 Side by Side Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
