Question about Kenmore HE2 Plus Front Load Washer
The door is stuck in lock mode. How do I unlock it?
    Genius:
  • 1,400 Answers
Hello
There should be a pause button on the console,hold down for 3 seconds to cancel wash.
Or unplug machine from wall.
Posted on Mar 31, 2011
Drivers side door closed and will not open.
Remove inner door latch and try operating the rod manually (vice grips). If locked, spray everything inside the door with WD-40 or the like and try operating the lock.
Aug 15, 2016 | 2011 Honda Fit Sport
Craftsmen garage door opener stuck in lock mode
Push and hold the lock button on the wall console for 3 seconds and that will unlock it.
Feb 13, 2015 | Craftsman 1/2 HP CHain Drive Garage Door...
Hi, My 2013 Toyota RAV4 front passenger door lock is caught. It sounds like it locks/unlocks- but we can't get it open-seems caught. How can we fix this? We don't use keys, always have fobs in our poc
SO DOES THE METAL KEY WORK OR NOT?
If the electonics magic fails , this is first., right?
just passenger door?
so locks can jam, and can be very hard to fix.
object stuck there, (closing door with junk in hands)
also playing with latch, by kids can trip it into an illegal mode.
first get it closed, 100% is it.
then use the key, if that don\'t work it needs service.
the key is for emerancies, say baby stuck in car, so..... use it.
Dec 20, 2014 | 2013 Toyota RAV4
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
Hatch back will not open
With key in hand,hit power door lock switch to lock. Raise release handle & lower. Hit power door lock unlock raise & lower handle. May take a couple times is stuck in limbo between lock & unlock mode.
Jun 07, 2010 | 2001 Volvo V70
1998 e-150 power locks are stuck in the unlock mode
The rear door lock/unlock switch was the problem. When I took it apart, I found the wire connectors were corroded. I cleaned them up and it is now functioning well.
Jun 20, 2009 | 1998 Ford Econoline
Door lock broken - stuck in "clean" mode
push cancel on the clock control and listen for the door interlock switches to acticate and unlock the door if you hear them then wait till you hear nothing going on and see if you can open the door
Apr 12, 2008 | Frigidaire GLEF396 Electric Kitchen Range
Kenmore HE2 Plus Front Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
