Question about Garden
When storing a gasoline snow blower, what is the best procedure? Should I drain the carborator or should I leave gas in it? I always use stabilizer in the gas. Do you find one type of stabilizer is better than others? I assume the same advice applies to other small engines like lawn mowers, blowers and trimmers in their season. Are there any different recommendations for these? Thank you!!!
  • 718 Answers
If you have been using stabilizer and it works for you by all means stick with it. I personally take the fuel out and then run the remaining fuel out of the system if you use quality gas there is usually never a problem starting up next season.I have never used stabilizer in any of my equipment and never had issues Use you best judgment it sounds like you got a handle on it . Good Luck...
Posted on Apr 01, 2011
I have a toro 826 snowblower and i cant get the thing to start there is no primmer bulb i dont know if the choke lever goes down to start?
https://www.toro.com/en/homeowner/snow-blowers/power-max-826-oe-37772
Click on parts and manuals then select the year that it was made and then you can download the operators manual.
The most common cause of failure to start is bad gasoline, Gasoline cannot be left in the fuel tank without a stabilizer added to it. It goes bad after about 1 month.
Nov 20, 2016 | Garden
Snow blower starts than it dies out I changed the spark plug new gas don't know whats the problem
I suspect the carburetor needs cleaning. Gas nowadays is terrible on equipment that sits for long periods of time (like a snow blower) without being used. The gas nowadays goes stale very quickly and gums up the carburetor. To prevent these issues use a gas stabilizer. I have stabilizer in all my jerry cans of gas. That way everything I fill up is ready to be stored at any time.
I'll give you an example of how bad the gas is.... My neighbour bought a new lawn mower. Selling feature of the mower was "guaranteed to start first or second pull". The next year it wasn't starting properly so he took it back. He was told he didn't store the mower properly over the winter (He didn't use a gas stabilizer) so no warranty. Took the carb apart and cleaned it ran like a champ....
Jan 29, 2016 | Toro Power Clear 621 R
Will not start.but backfires..why?
Clean the spark plug, it might be dirty causing misfire.
Timing might be off, take to repair shop for this.
Feb 13, 2015 | Toro Power Clear 418 ZE - Single Stage...
I have a Craftsman Snow Thrower model # 247.881731. At the end of last year I drained the gas as recommended in the manual, this year I filled it with fresh gas and it now has a problem starting. I pu
Draining the gas from the tank doesn't drain the float bowl in the carburetor. It still had last year's gas in it. Gas will start to turn to varnish if left sitting 6 to 12 months. You'll probably have to remove the carburetor, disassemble it and clean it out with Gumout carb cleaner or some similar product.
When you get it running and the snow's over and done with, put some Stabil in the gas tank to prevent the gas from converting to varnish and then start it up and run it until that stabilized gas is through the carburetor and into the engine. You can leave it with the treated gas in the tank.
Feb 01, 2015 | Craftsman Snow Blower 26 In. 208CC...
I have a 24" Craftman snow thrower that gas got into and mixed with oil, and does not start.
Vito,
Don't feel bad. This is the most common problem for small engines. Because of the EPA demanding the use of corn alcohol in fuels the shelf life of fuel is 60 days or less.
This is not a problem for most cars because we cycle the fuel. unfortunately for small engines this is not always the case. I recommend the use of non ethanol fuel if possible.
The next best option is to stabilize fresh fuel with Stens 770-843 and keep it in a air tight can like the 765-102
( 765 102 2 1 2 Gallon Fuel Can )
(770 843 Gasoline Additive )
I put together a video describing the problem and how to fix it here:
https://www.youtube.com/watch?v=Rhbhbbus-BE
Please let me know if you have any other questions.
Best,
Joe
barterjoes.com
Jan 27, 2015 | Garden
I have a 2003 pt cruiser. It was sitting for 8 months. I change d the water pump and put a new battery. but it wont turn over.
the gas has turned bad shudda put a stabilizer in it-always drain tank and fuel system when storing--the throttl area may hav effected and a pro cleaning mite hav to be done--ethanol gas makes it worse-try to use pure gasoline-is more xpensiv but worthit
Aug 22, 2014 | Cars & Trucks
We have spark and gas but still won't start
you need to take the carb off and give it a full cleaning not just drop the bowl.
Mar 16, 2014 | MTD Genuine Factory Parts MTD 954-04014...
Bike running rough at lower revs
If the bike sat without being used over the winter It could be bad gas. if gas sits without being used for an extended period of time it destabilizes and gums up carborators and fuel injectors, you need to add a fuel stabilizer to gas when storing for winter. To fix the problem the gas has to be drained from tank, then refil with fresh gas and appropriate amount of carborator/fuel injector cleaner/treatment. Then start the bike and let it run it should clean itself out and start running smooth. If bike did not sit unused for winter its possible they installed the wrong plugs sometimes they talk you into spending more money on platinum or split fire/gimmick plugs (always use the exact same plug that came in the bike when it was new!!!!!)
Mar 17, 2012 | Triumph Rocket III Touring Motorcycles
Last year I purchased a Troy Bilt snow blower . I used it one time after using it I drained the gas out of it. Just recently I got it out and was checking it out because they were talking about snow so it...
Cecil,
I am curious why this repair was not covered under the warranty? This snow blower has a 2 year warranty from the manufacture.
Two things for you.
First, there has always been the "what came first, the chicken or the egg" issue over leaving fuel or draining the fuel from you snow blower. Half the experts say drain it, and the other half say leave it in.
Secondly, all of the current Cub Cadet, Craftsman, Troy-Bilt, Yard Machine, and Yardman snow blowers with the Powermore engine need to be treated differently than the old Techumseh or Briggs side-valve that you were used to.
The issue with your Powermore engine is actually today's ethanol fuel. If you leave the ethanol blends in your tank without a fuel stabilizer the alcohol separates from the gas. This alcohol then rises to the top of the tank and gets into the fuel lines. The fuel lines actually will soften. (I've seen the primer bulb actually melt on a few units)
If you drain the tank and run it dry the remaining fuel will "varnish" and/or dry out the carb.
I know a service manager that repairs a lot of these Powermore motors. Instead of replacing the carb, his techs actually take the carb off, soak it overnight in carb cleaner and then reinstall it. This is so common that he keeps a few clean carbs on the shelf and then just switches them out when a customer has a problem.
So how do you keep from getting those high repair bills? First, use fuel stabilizer ALL THE TIME! Mix Sta-Bil, Sea Foam, or Craftsman Fuel Stabilizer according to the directions on the bottle. Secondly, try not to use ethanol blended fuel. Especially try to fill the tank the last time you use it in the spring with non blended fuel. Third, When you put your snowblower away, fill it with stabilized fuel, start the motor and run it until warm. Then "fog" the carb with SeaFoam spray until it loads up and quits running. Put it away for the season. (If you don't know how to fog go to SeaFoam's website and read about doing this with the spray)
It will start next fall.
Feel free to ask me any other questions about your snow blower. Don't forget to rate this answer and you are welcome to leave a comment about it.
Jan 11, 2011 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
