Washer wil do everything else except the spin cycle. I hear it click on and then it trys to do something and then nothing. I smell something burning like electronic. Don't know why?
    Genius:
  • 1,400 Answers
Hello
Possible door switch or magnet is faulty.This will stop washer from going into spin for saftey reasons.
You can try jumping out the switch and see if you get a spin cycle.But it will need to be replaced.
Posted on Mar 31, 2011
Kenmore model 11020842990 series 80. had a severely unbalanced load in the rinse cycle. opened lid, rearranged clothes, would not start up again. Removed clothes to dryer, luckily most of water had...
when it went unbalanced the tub most likely broke the lid switch part
3949238.open the lid,on the right side of lid you'll see a strike,it goes into a hole and this is where the lid switch is,stick a screw driver into the hole,if you don't hear a clicking sound the switch is broke
http://www.youtube.com/watch?v=MFsvLiuTniU
Oct 15, 2013 | Kenmore 24032\24036 Top Load Washer
Clicks only when in wash or spin cycle
try the compasster like a white or sliver battaRIE looking thing with two wires
Jan 17, 2013 | Washing Machines
Frigidaire FEX831FS2 stack washer/dryer; it washes, but when it goes into spin cycle it does not spin and you can smell something "funny" burning up like a motor or something. This is what the...
well, The transmission hears turns 2 ways. One way to wash (which causing the agitator turn) and the other to spin. The motor also turns 2 way. If you say it washes fine and in spin cycle is where you get burning smell, maybe of many things: Bad transmission locking up motor causing the burning smell. Possible bad motor trying to start (bad start winding or capacitor). Maybe something simple as something getting stuck in between outer tub and inner basket. Something you can do to check the motor mechanically is disconnect the belt from the transmission pulley and put the time on spin cycle. If the motor shaft/pulley spins on start up then the next thing to look into is the transmission or something catching it from spinning. Check the inside of the washer, if the basket is the type with small holes, make sure there is nothing stuck in any of the whole. Iv seen small screws getting lodged in there and preventing the basket from spinning. You can start by doing simple checks like this to start narrowing down things. Open the front panel form the washer and see if you have access to the belt, if not then you have to tilt the unit to get under it. if you have money and dont want to bother dealing with the unit then replace it. But i like investigating things first. go with whirl pool if you replace it. let me know if what you find if you do make these checks.
Sep 10, 2011 | Washing Machines
Washer makes alot of noise
time to replace the belt , might need a tub bearing too / tentioner pully might have froze . remove the back panel with the washer unpluged look to see if the tentioner is at its fullest possition if so replace the belt .
Sep 06, 2009 | Maytag PAV2300 Top Load Washer
AFTER SPINNING, WATER IS LEFT SOMEWHERE IN THE DRUM. i CAN'T SEE IT BUT CAN HEAR IT AND THE WASHER SMELLS BAD.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
May 31, 2009 | Estate TAWX700JQ Top Load Washer
Washer stopped spin cycle smell like burning rubber
hello if the belt is broken quite easy to put back on .take the back off you should see the belt if it has snaped or just come off .at the bottom of the washer you should see the motor at the back of the motor you should see 2 nuts this holds the motor on get a felt tip pen and mark the 2 nuts where they are fixed so you know where to tighten back on . get spanner and loosen the 2 nuts the motor should drop down put the belt back on and tighten up good luck
shaun
Mar 31, 2009 | GE Washing Machines
Kenmore 90 series - clicking during slugish spinning cycle
try your unit on a outlet by it self ,,nothing can be on this line,,sounds like weak ampage,,this machine needs 15 amps line by it self...
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Washer will not start
It sounds like the lid switch may be bad or have come loose. Open the lid and there should be a thing on the underside that pokes into the washer when you close it. At the place where it pokes into the washer you should see the top of the lid switch and it should be flush with the washer body. Stick a screwdriver into that hole to push down the switch and it should click. Pull the screwdriver out and it should click again. If it does click then close the lid slowly and listen closely near the switch to see if you still hear the clicking.
If you don't hear the clicking, then you will have to change the lid switch (usually costs about 30-50 dollars) or just bypass it. If you do bypass it, be careful. It will still spin even with the lid open and can be dangerous.
Dec 05, 2007 | Roper RAX4232KQ Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
