What does error code f-17 on my bosch logixx 88 sensitive washingmachine mean?
  • 1294 Answers
SOURCE: Bosch logixx 1600 workshop manual
Look for user manuals at http://www.user-manual-search.com
Posted on Mar 14, 2008
SOURCE: Bosch washing machine logixx 8 front loader error
Det er for koldt i rommet, eller vandrør har frosset til.Sett opp temperatur i rommet eller tine rør
Posted on Jan 15, 2010
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
SOURCE: bosch logixx code f-23 .wat does it mean?
it means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
Posted on Aug 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Bosch washing machine (logixx
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Mar 03, 2015 | Bosch Washing Machines
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
I have a bosch logixx sensitive washing machine code F:43 is displaying what does it mean
Hi there. After doing some research, I've discovered you need to either reset the machine by doing various on/off/pause/spin actions in a certain sequence (the sequence depends on your E-Nr number), or that there is a problem with the main control board.
Oct 11, 2013 | Washing Machines
Hello can you please help me.. i have a big problem with my washing machine error on F43 Bosch logixx sensitive can you send me what the problem is.. Rune from norway
For Bosch Logixx, F42, F43 and F44 all decode as 'motor fault indicated'. Sorry ;-0)
I changed the motor on our Bosch (not a Logixx) at a cost of GBP250! I do expect it to last another 20 years, though.
If this has assisted you please score accordingly.
Thanks and good luck!
John C
Apr 12, 2011 | Washing Machines
F42 is showing on my Bosch Logixx 8 sensitive washing machine what does this mean and how do I fix it . thanks
An error code of "F42" means your oven has a defective or jammed lower latch, latch motor or latch switch, which is preventing the lower oven's latch from locking properly. If all of the electrical connections are in place on your oven's power board, you may have a faulty power board.
Apr 01, 2011 | Bosch Washing Machines
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
Sep 24, 2010 | Washing Machines
F:23 code logixx edition75
Hope this helps.
Jul 07, 2010 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
