Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size setting. Then print again. This message pops up when i try and print?!?! For love or money i cant work out why it wont print.........please help
  • richpalmer80 Mar 31, 2011
    I have a mac!!! I've checked the paper size and all the settings more than once, still no joy, im ready to smash it up!!!!
    Scholar:
  • 104 Answers
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
Posted on Mar 31, 2011
HOW TO FIX ERROR CODE 094-534
Make Sure the Paper Trays Are Configured With the Correct Paper Size, Type, and Color
To configure settings for Paper Trays 1 and 2
  1. Open the paper tray.
  2. Make sure that the required paper stock is loaded in the paper tray, and that the paper edge guides are adjusted properly to fit the size of the paper.
  3. Close the paper tray. The Printer Settings screen will be displayed on the Touch Screen.
  4. Select [Size], and then select the size of paper loaded in the tray. If this is a standard size paper, the correct size will be selected automatically if the paper guides are adjusted correctly. If necessary, select [Custom] to enter the paper size if the required size is not displayed and then enter the required X and Y values.
  5. Select [Save].
  6. Select [Type], and then select the type of paper loaded in the tray.
  7. Select [Color], and then select the color of paper loaded in the tray.
  8. Select [Confirm].
Nov 11, 2016 | Xerox ColorQube 9201P
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
We are getting an error that says Change MP Feeder C5 on our Dell M5200. It will not print.
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Jul 21, 2011 | Dell M5200n Laser Printer
My printer will not pull paper from the manual tray. I am trying to print envelopes and postcards from the manual tray. Even when I select manual tray in the "paper source" field it will not pull. I think...
Check the Paper Handling Menu. The Tray 1 size and Tray 1 Type should be set to Any Size. This means that the printer should pull the paper from Tray 1 first when paper is loaded in tray 1
Oct 15, 2009 | HP P4515TN LaserJet Printer with 500 Sheet...
HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue. Step one: Reset the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Wait 30 seconds, and then plug the power cord into the back of the product.
  3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
Step two: Check the condition of the paper and reload it
  1. Lift the photo tray lid.
  2. Slide the paper width guide all the way to the left.
  3. Remove the paper from the tray.
  4. Replace any ripped, dusty, wrinkled, or bent paper.
  5. Make sure that the stack of paper contains only one type of paper.
  6. Tap the paper stack on a flat surface to align the edges.
  7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
  8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
  9. Lower the photo tray lid.
  10. Extend the paper catch.
  11. Try to print the job one more time.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step three: Choose the photo tray in the print driver settings
  1. Open the document to print.
  2. Click File , and then click Print . The Print window opens.
  3. Click Properties . The Properties window opens.
  4. Click Printing Shortcuts , and then click the shortcut you want to use.
  5. From the Paper source drop down list, click the paper source.
  6. From the Size is drop down list, click the paper size.
  7. From the Type is drop down list, click the paper type.
  8. Click OK , and then click OK again to print the document.
  • If the issue persists , try the following Workaround.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Sep 08, 2009 | HP Photosmart 8250 InkJet Printer
Error message unable to print
1.The printer is asking you to manualy load the right size paper.
source tray possibly tray 1
2. The printer has finished printing the first side of a manual-duplexed job and is waiting for the pages to be reloaded so it can print the second side. Reload the pages.
3.you are trying to print to the source (tray) and there is no paper in the selected tray. laod paper trays.
4. The print image is larger than size of paper in the tray. Load the right size paper. Press go Button
Jan 02, 2009 | HP LaserJet 2550L Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Canon Imagerunner 210S - A3 error
A3 is a metric size paper. The document you are trying to print must have been formated for metric size paper. When you print select "Fit to printer margins" De-select "Choose paper source by PDF page size" and select the proper page size and source.
Jun 09, 2008 | Canon imageRUNNER 210S Copier
146 people viewed this question
jasbo
jasbo
